| » Access to ignitor assembly?? |
Model Number: WGD5600SQ0 Brand: Kenmore Age: 5 - 10 years
In order to access the ignitor assembly on my dryer, do I have to take the entire front panel off? There isn't a kick plate at the bottom.
Related Models |
You will need to bust the dryer open to get to all of the lint, inspect the rollers and belt. Start by yanking out the filter. Remove those 2 phillips screws in the top of the filter housing so you can pop the top. Get the screws out that hold the front panel on. Important: lift UP the front panel to release the lower clips to prevent them from breaking! Get the drum out. Oil the rollers and idler assembly, Vacuum it all out real good. Oil the Idler using non-flammable, high temperature resistance, zoomspout oil. (ace hardware $3). a standard Dryer Manual from Whirpool Corp: |
| Display Modes | |
| How to access the ignitor on my gas dryer? | wduke28 | Dryer Repair | 1 | 07-18-2009 04:44 AM |
| Access Ignitor | gilroy1962 | Dryer Repair | 0 | 06-27-2009 09:13 AM |
| Access To The Heat Duct Assembly-coils | shirleyc | Dryer Repair | 4 | 05-15-2009 07:45 PM |
| Access Burner Assembly | frost | Dryer Repair | 3 | 05-07-2009 06:54 PM |
| ge fridge cover access assembly? | wendys | Refrigerator & Freezer Repair | 1 | 02-12-2008 02:15 PM |
