Discuss
Maytag Dryer Automatic Setting - Keeps Running
 in
Dryer Repair
Maytag Dryer MDG2500BWW shuts down on Timing Setting, but it keeps running on the Automatic Setting--and does not shut off.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer Automatic Setting - Keeps Running
  #1 (permalink)
Old 10-03-2009, 01:29 PM
Junior Member
Robert W. Thomas is on a distinguished road
Default Maytag Dryer Automatic Setting - Keeps Running
Model Number: MDG2500BWW   Brand: Maytag   Age: 1 - 5 years
Maytag Dryer MDG2500BWW shuts down on Timing Setting, but it keeps running on the Automatic Setting--and does not shut off. I changed the Timer today (Part 330016320) --and the same result: shuts down on regular Timing Setting--but still no change on Automatic Setting as it keeps running.
Does the Timer control the Automatic Setting--or is it controlled by another part?
Thank you for your help.
Robert W Thomas
Ads By Google
Related Models
Maytag MDG2500BWW Dryer - Gas
Maytag MDG2600BWW Dryer - Gas
Maytag MDG26CSAAG Dryer - Gas
Maytag MDG26CSAAL Dryer - Gas
Maytag MDG26CSAAW Dryer - Gas
Maytag MDG26CSABG Dryer - Gas
Maytag MDG26CSABL Dryer - Gas
Maytag MDG26CSABW Dryer - Gas
Maytag MDG26CSAGG Dryer - Gas
Maytag MDG26CSAGL Dryer - Gas
Maytag MDG26CSAGW Dryer - Gas
Maytag MDG26CTAAG Dryer - Gas
Maytag MDG26CTAAL Dryer - Gas
Maytag MDG26CTAAW Dryer - Gas
Maytag MDG26DAAAG Dryer - Gas
Maytag MDG26DAAAL Dryer - Gas
Maytag MDG26DAAAW Dryer - Gas
Maytag MDG26DAABG Dryer - Gas
Maytag MDG26DAABL Dryer - Gas
Maytag MDG26DAABW Dryer - Gas
Maytag MDG26MNAAG Dryer - Gas
Maytag MDG26MNAAL Dryer - Gas
Maytag MDG26MNAAW Dryer - Gas
Maytag MDG26MNABG Dryer - Gas
Maytag MDG26MNABL Dryer - Gas
Maytag MDG26MNABW Dryer - Gas
Maytag MDG26MNAGG Dryer - Gas
Maytag MDG26MNAGL Dryer - Gas
Maytag MDG26MNAGW Dryer - Gas
Maytag MDG26PCAAG Dryer - Gas
Maytag MDG26PCAAL Dryer - Gas
Maytag MDG26PCAAW Dryer - Gas
Maytag MDG26PCABG Dryer - Gas
Maytag MDG26PCABL Dryer - Gas
Maytag MDG26PCABW Dryer - Gas
International MDG2706AGW Dryer - Gas
Maytag MDG2706AWW Dryer - Gas
Maytag MDG270SAWW Dryer - Gas
Maytag MDG27CSABL Dryer - Gas
Maytag MDG27CSABW Dryer - Gas
Maytag MDG27CSAGL Dryer - Gas
Maytag MDG27CSAGW Dryer - Gas
Maytag MDG27CTABL Dryer - Gas
Maytag MDG27CTABW Dryer - Gas
Maytag MDG27MNAAW Dryer - Gas
Maytag MDG27MNABW Dryer - Gas
Maytag MDG27MNAGW Dryer - Gas
Maytag MDG27PCAAL Dryer - Gas
Maytag MDG27PCAAW Dryer - Gas
Maytag MDG27PCABL Dryer - Gas
Maytag MDG27PCABW Dryer - Gas
Maytag MDG3000AWA Dryer - Gas
Maytag MDG3000AWQ Dryer - Gas
Maytag MDG3000AWW Dryer - Gas
Maytag MDG3000AXA Dryer - Gas
Maytag MDG3000AXQ Dryer - Gas
Maytag MDG3000AXW Dryer - Gas
Maytag MDG3001AWW Dryer - Gas
International MDG3050AAW Dryer - Gas
International MDG3050AEW Dryer - Gas
International MDG3050AGW Dryer - Gas
Maytag MDG308DAWW Dryer - Gas
Maytag MDG30MC2A*
Maytag MDG30MC2AL Dryer - Gas
Maytag MDG30MC2AQ Dryer - Gas
Maytag MDG30MC2AW Dryer - Gas
Maytag MDG30MC2Ax Dryer - Gas
Maytag MDG30MC3A Dryer - Gas
Maytag MDG30MC3AL Dryer - Gas
Maytag MDG30MC3AW Dryer - Gas
Maytag MDG30MNAWW Dryer - Gas
Maytag MDG30MNVWQ Washer/dryer Laundry System
Maytag MDG30MNVWW Dryer - Gas
Maytag MDG30PC2A*
Maytag MDG30PC2AL Dryer - Gas
Maytag MDG30PC2AQ Dryer - Gas
Maytag MDG30PC2AW Dryer - Gas
Maytag MDG30PC2Ax Dryer - Gas
Maytag MDG30PC3AL Dryer - Gas
Maytag MDG30PC3AW Dryer - Gas
Maytag MDG30PCCWQ Dryer - Gas
Maytag MDG30PCCWW Dryer - Gas
Maytag MDG30PN3AL Dryer - Gas
Maytag MDG30PN3AW Dryer - Gas
Maytag MDG30PNHWQ Dryer - Gas
Maytag MDG30PNHWW Dryer - Gas
Maytag MDG30PNVWQ Dryer - Gas
Maytag MDG30PNVWW Dryer - Gas
Maytag MDG31PDAWS Dryer - Gas
Maytag MDG31PDAWW Dryer - Gas
Maytag MDG31PDSWS Dryer - Gas
Maytag MDG31PDSWW Dryer - Gas
Maytag MDG31PNAWW Dryer - Gas
Maytag MDG31PNSWW Dryer - Gas
Maytag MDG32PC2 Dryer - Gas
Maytag MDG32PC2AL Dryer - Gas
Maytag MDG32PC2AW Dryer - Gas
Maytag MDG32PC3AL Dryer - Gas
Maytag MDG32PC3AW Dryer - Gas
Frigidaire MDG336MBD0 Wwh(v10) / 27 " Gas Dryer
Frigidaire MDG336MBD1 Wwh(v1) / Gas Dryer
Frigidaire MDG336MBD2 Kel(v15) / Gas Dryer
Frigidaire MDG336MBW0 Tap(v11) / 27 " Gas Dryer
Frigidaire MDG336MBW1 Wwh(v2) / Gas Dryer
Frigidaire MDG336MBW2 Gib(v10) / Gas Dryer
Frigidaire MDG336MBWD0 Wwh(v10) / 27 " Gas Dryer
Frigidaire MDG336MBWL0 Frg(v4) / 27 " Gas Dryer
Frigidaire MDG336MBWW0 Gib(v15) / 27 " Gas Dryer
Frigidaire MDG336RBD0 Frg(v4) / 27 " Gas Dryer
Frigidaire MDG336RED0 Frg(v1) / Gas Dryer
Frigidaire MDG336RED1 Frg(v1) / Gas Dryer
Frigidaire MDG336RES0 Frg(v2) / Gas Dryer
Frigidaire MDG336RES1 Frg(v0) / Gas Dryer
Frigidaire MDG336RES2 Frg(v0) / Dryer
Frigidaire MDG336REW0 Frg(v3) / Gas Dryer
Frigidaire MDG336REW1 Frg(v2) / Gas Dryer
Maytag MDG3500BWQ Dryer - Gas
Maytag MDG3500BWW Dryer - Gas
Maytag MDG3600BWQ Dryer - Gas
Maytag MDG3600BWW Dryer - Gas
  #2 (permalink)
Old 10-03-2009, 04:23 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
The sensor judges dampness inside the drum, and powers up the timer motor when the clothes are dry. Fabric softener can pile up on the sensors and make the dang thang think the clothes is still wet. Find the sensors below the filter inside the drum and clean em up.
  #3 (permalink)
Old 10-04-2009, 02:32 PM
Junior Member
Default JW: Thank You--Still Having Trouble
JW:
Thanks so much for trying to help me. I removed the lint screen and I have to assume the Moisture Sensor behind it was what held the lint/debris which was caked on. I cleaned it and used alcohol as you suggested. Unfortunately, I set it on Automatic and it still will not shut off even with the brand new Timer.
Is this where the Moisture Sensor is located? It is a curved white plastic behind the lint screen.
Again, JW, my wife and I thank you for your advice and counsel.
Robert W. Thomas
  #4 (permalink)
Old 10-04-2009, 04:40 PM
Senior Expert
APP Volunteer
Default
Look at the wiring diagram. The control thermostat(cycling thermostat) has a orange wire going up to the timer motor, it must be malfunctioning, I would replace it.
  #5 (permalink)
Old 10-04-2009, 05:01 PM
Senior Expert
APP Volunteer
Default
I realize this is an electric dryer but it clearly shows the location of the cycling thermostat on a maytag dryer:
  #6 (permalink)
Old 11-15-2011, 09:06 AM
Junior Member
dasprdav is on a distinguished road
Default MDG2500BWW Not Heating or Advancing on Auto Setting
I am having the same issues with this dryer. I have tested the Cycling Thermostat for continuity and it shows closed across the outer 2 poles. I was wondering what should be happening and how do you test the other 3 poles on the top of the thermostat?
  #7 (permalink)
Old 11-16-2011, 09:01 AM
Senior Expert
APP Volunteer
Default
Warm it up using a simple torch. When you hear the click test for continuity.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dryer timer wont work on automatic setting dirtracer9 Dryer Repair 2 11-26-2009 06:35 AM
Automatic Fan running continuously Curlz Microwave Repair 1 06-15-2009 06:53 PM
Amana Dryer won't stop running in automatic ricklerm Dryer Repair 0 01-23-2009 06:41 PM
Dryer won't stop running in automatic mode jgk Dryer Repair 5 11-03-2008 01:51 AM
Automatic dryness setting not working Ben T. Dryer Repair 3 11-19-2007 06:56 PM
