HI As the title states, my dryer is not heating. I have tested sensors and switches and all test ok. When I go into diagnostic mode there are no error codes displayed. While in diagnostic mode if I press the start button the motor starts and I also get heat, but for some reason there is no heat when running normally. Thanks
