Discuss
Belt replacement help
 in
Dryer Repair
I need to replace my dryer belt bc the dryer doesn't tumble. How do I get to the inside of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Belt replacement help
  #1 (permalink)
Old 03-11-2013, 10:38 AM
Junior Member
applianceissues is on a distinguished road
Default Belt replacement help
Model Number: 2004 DE313   Brand: Maytag   Age: 5 - 10 years
I need to replace my dryer belt bc the dryer doesn't tumble. How do I get to the inside of the dryer in order to put the new belt on? Somebody please help me, I have a ton of laundry to do!!
Related Models
Amana 2008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.100 COMMERCIAL MICROWAVES
Amana 2008.101 COMMERCIAL MICROWAVES
Amana 2008.102 COMMERCIAL MICROWAVES
Amana 2008.112 COMMERCIAL MICROWAVES
Amana 2009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 200A-30 ROOM AIR CONDITIONER
Amana 200A-30H ROOM AIR CONDITIONER
Amana 200A-3HN ROOM AIR CONDITIONER
Amana 200A-3M ROOM AIR CONDITIONER
Amana 200A-3N ROOM AIR CONDITIONER
Amana 200A-3P ROOM AIR CONDITIONER
Amana 200A-3PH ROOM AIR CONDITIONER
Amana 200A-3R ROOM AIR CONDITIONER
Amana 200A-3RH ROOM AIR CONDITIONER
Amana 200C-3P ROOM AIR CONDITIONER
Amana 200C-3PH ROOM AIR CONDITIONER
Amana 200C-3R ROOM AIR CONDITIONER
Amana 200C-3RH ROOM AIR CONDITIONER
Amana 200C-8P ROOM AIR CONDITIONER
Amana 200C-8RH ROOM AIR CONDITIONER
Amana 201.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 201.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 201.700 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2010
Hoover 2011
Jenn-Air 20135 RANGE- S/C D/I DDRAFT ELE
Hoover 2017
Amana 2018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.004 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 20236 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 20237 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 20239 RANGE- S/C S/I DDRAFT ELE
Roper 2025B0A Ranges, Electric*
Roper 2035B0A Ranges, Electric*
Roper 2035B1A Ranges, Electric*
Amana 2036.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2036.005 MWAVE - FAMILY SIZE (60 HZ)
Amana 2036.104 COMMERCIAL MICROWAVES
Amana 2036.105 COMMERCIAL MICROWAVES
Amana 2039.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.004 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2040
Roper 2045B0A Ranges, Electric*
Roper 2045B1A Ranges, Electric*
Hoover 2048
Amana 2052.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2055B0A Ranges, Electric*
Roper 2055B1A Ranges, Electric*
Roper 2055B2A Ranges, Electric*
Roper 2065B0A Ranges, Electric*
Roper 2065B1A Ranges, Electric*
Roper 2065B2A Ranges, Electric*
Amana 2070.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2071.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2075B0A Ranges, Electric*
Roper 2075B1A Ranges, Electric*
Roper 2075B2A Ranges, Electric*
Amana 2085.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2089.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2091.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2092.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2092B0A Ranges, Electric*
Roper 2092B1A Ranges, Electric*
Roper 2092B2A Ranges, Electric*
Roper 2092B3A Ranges, Electric*
Amana 2094.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2095B0A Ranges, Electric*
Roper 2095B1A Ranges, Electric*
Roper 2095B2A Ranges, Electric*
Amana 210-3B ROOM AIR CONDITIONER
Hoover 2100
Roper 2101*0E Ranges, Electric*
Roper 2101*1E Ranges, Electric*
Roper 2101*2E Ranges, Electric*
Amana 21011 COMMERCIAL MICROWAVES
Amana 21016 COMMERCIAL MICROWAVES
Roper 2101W0E Ranges, Electric*
Roper 2101W1E Ranges, Electric*
Roper 2101W2E Ranges, Electric*
Roper 2102*0E Ranges, Electric*
Roper 2102*1E Ranges, Electric*
  #2 (permalink)
Old 03-11-2013, 01:47 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Unplug the dryer.
Locate and remove two screws at the bottom portion of the front panel. Pull the lower portion of the panel out and release it from the top clips.
Remove the 4 screws holding the bulkhead and remove the bulkhead.
Go to the back of the dryer, locate and remove the square cover in the right lower corner.
Memorize the way the belt is installed if it's still installed, take it off the pulleys.
Return to the front and remove the old belt. Put the belt on. The grooves on the belt should be facing outside.
Part number: AP4290988
Here are the breakdown diagrams and 07-Rear View parts for Maytag DE313 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Belt replacement reknez Dryer Repair 0 11-10-2011 02:04 PM
Belt replacement splacido Washer Repair 1 09-25-2011 06:29 PM
belt replacement herman Washer Repair 1 11-29-2010 08:13 PM
belt replacement jpl874@yahoo.com Dryer Repair 1 10-07-2010 10:12 PM
Belt Replacement Flapr Dryer Repair 2 03-03-2008 07:29 PM
