Discuss
A mind of it's own
 in
Dryer Repair
I have an Amana Electric Dryer # ALE643RAW. The problem is the timer will intermittently stop turning and the dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » A mind of it's own
  #1 (permalink)
Old 03-09-2013, 05:51 AM
Junior Member
Fred the Fixer is on a distinguished road
Default A mind of it's own
Model Number: ALE643RAW   Brand: Amana   Age: 5 - 10 years
I have an Amana Electric Dryer # ALE643RAW. The problem is the timer will intermittently stop turning and the dryer will continue forever at whatever spot the timer is at. Whether it be in the cool down stage, 41, 27, 16 or however minutes left on the dry cycle the timer will not advance on its own. But then again about half the time it completes its timed cycle properly (heat, cool down, buzzer, off). If I advance the timer manually after it stops turning while the dryer is still on it will then continue on to finish the timed dry properly. So I never know when it is going to act normal or get stuck in the twilight zone. Please help, I was just going to order a new timer but figured I would check here first. Thank You
Related Models
Amana ALE643RAW DRYER- ELE
Amana ALE643RBC DRYER- ELE
Amana ALE643RBW DRYER- ELE
Amana ALE643RCW DRYER- ELE
Amana ALE665SAC DRYER- ELE
Amana ALE665SAW DRYER- ELE
Amana ALE866SAC DRYER- ELE
Amana ALE866SAW DRYER- ELE
Amana ALE866SBC DRYER- ELE
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
  #2 (permalink)
Old 03-09-2013, 07:48 AM
Junior Member
RKF22 is on a distinguished road
Default
Timer motor. Little round motor on the timer. Some you can replace just the timer motor, some you have to buy the whole timer.
  #3 (permalink)
Old 03-09-2013, 09:17 AM
Junior Member
Default
1st off what your saying is it definitely sounds like the timer. Secondly is there anything I can do to attempt to fix the motor part of the timer (electrical contact cleaner/lubricant)? If not I guess I will see if I can get a part number off the motor itself and or replace the whole timer. Lastly thanks for your response, it is greatly appreciated!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag (MDB-8) Has a Mind of it's Own :( jonesynyc Dishwasher Repair 1 09-04-2012 02:07 PM
GE freezer has mind of its own. deet Refrigerator & Freezer Repair 0 06-27-2011 01:00 PM
mind of it's own kevin owen Dishwasher Repair 0 08-30-2010 12:02 PM
Mind of its own! terrylrs Dishwasher Repair 2 10-23-2009 06:32 AM
mind of its own 2040820408 Washer Repair 0 11-12-2007 12:47 PM
