Parts for Whirlpool YWED9200SQ0 Dryer - AppliancePartsPros.comSee the attachment for the tech sheet.
Unplug the unit.
Unplug the inlet thermistor at the control board.
Plug unit in.
Check for the error code
If it changes from F25 (shorted) to F24 (open), then odds are that the thermistor needs replacing.
To confirm this check it with a meter, see table C on Page 10.
If the error code stays at F25 then the board is toast.
Your refurbished board is probably no good.
You could try the following but I doubt it will help as the od board does not show any communication errors.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
