Sgt.D
#1 Posted : Thursday, March 7, 2013 11:54:50 AM(UTC)
Sgt.D
My sister dyer had this annoying squeaky noise when its been used. I have it opened, looks every parts and it seems okey but maybe burnt out just like the bulb. Anyway, I applied some W40 on the pulley (where the belt is located, rear bearing drum, the hole where the bearing goes in and it works for a while not until it reach the 3 minutes marked where its started to squeak again. What could be the problem Pros. Any suggestions?
Thanks again for your immediate respond.
sidfink43
#2 Posted : Friday, March 8, 2013 4:40:55 PM(UTC)
sidfink43
Usually on these GE models that kind of problem is the rear bearing/drum sleeve. You can see the parts on this diagram here.
Drum parts for GE DHDSR46EG1WW - AppliancePartsPros.com
You will need to take out the drum to fix it, you do this by taking off the top, then the front and then releasing the belt.
