Discuss
Maytag gas dryer
 in
Dryer Repair
Wiring of the replacment motor. only have four wires (red,black,yellow,white/blue). New motor runs, but burner will not start. Old motor
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag gas dryer
  #1 (permalink)
Old 03-07-2013, 05:24 AM
Junior Member
jstrand is on a distinguished road
Default Maytag gas dryer
Model Number: DG309   Brand: Maytag   Age: More than 10 years
Wiring of the replacment motor. only have four wires (red,black,yellow,white/blue). New motor runs, but burner will not start. Old motor had centifgual switch. The wires are now on the follwing terminals red=5 blue=1 black=2 yellow=6 white=thermal protector. What is need to get the burner to start?
Ads By Google
Related Models
Maytag DG309 Dryer - Gas
Maytag DG30CA Dryer - Gas
Maytag DG30CM Dryer - Gas
Maytag DG30CMD Dryer - Gas
Maytag DG30CT Dryer - Gas
Maytag DG312 Dryer - Gas
Maytag DG312D Dryer - Gas
Maytag DG313 Dryer - Gas
Maytag DG313D Dryer - Gas
Maytag DG31CA Dryer - Gas
Maytag DG31CM Dryer - Gas
Maytag DG31CT Dryer - Gas
Amana DG3240 Washer - Top Loading
Amana DG3250 Washer - Top Loading
Amana DG3261 Washer - Top Loading
Amana DG3280 Washer - Top Loading
Amana DG3281 Washer - Top Loading
Amana DG3291 Washer - Top Loading
Maytag DG32CA Dryer - Gas
Maytag DG32CM Dryer - Gas
Maytag DG32CT Dryer - Gas
Amana DG3300 Washer - Top Loading
Amana DG3331 Washer - Top Loading
Amana DG3341 Washer - Top Loading
Amana DG3350 Washer - Top Loading
Maytag DG33CA Dryer - Gas
Maytag DG33CM Dryer - Gas
Maytag DG34CD Dryer - Gas
Maytag DG34CQ Dryer - Gas
Frigidaire DG350RXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW3 Wwh(v2) / 27 " Gas Dryer
Amana DG3630 Washer - Top Loading
Amana DG3680 Washer - Top Loading
Amana DG3681 Washer - Top Loading
Amana DG3800 Washer - Top Loading
Amana DG3801 Washer - Top Loading
Maytag DG382 Dryer - Gas
Amana DG3860 Washer - Top Loading
Amana DG3861 Washer - Top Loading
Frigidaire DG3900ADD1 Frg(v6) / 27 " Gas Dryer
Frigidaire DG3900AWW1 Frg(v5) / 27 " Gas Dryer
Maytag DG4000 Dryer - Gas
Frigidaire DG400AXD1 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXD2 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXW1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400AXW2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG400EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG400EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG400EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG400EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG400EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG400EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG400EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG400EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG400EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG400EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG400EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG400EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG400EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG400JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG400JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG400JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG400JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG400KXD1 Wwh(v9) / Gas Dryer
Frigidaire DG400KXD2 Wwh(v9) / 27 " Gas Dryer
Frigidaire DG400KXD3 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD4 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD5 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXH1 Wwh(v8) / Gas Dryer
Frigidaire DG400KXH2 Wwh(v8) / 27 " Gas Dryer
Frigidaire DG400KXH3 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH4 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH5 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXW1 Wwh(v7) / Gas Dryer
Frigidaire DG400KXW2 Wwh(v7) / 27 " Gas Dryer
Frigidaire DG400KXW3 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW4 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400SXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400SXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD0 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXW0 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400TXW1 Wwh(v2) / 27 " Gas Dryer
Maytag DG406 Dryer - Gas
Maytag DG407 Dryer - Gas
Maytag DG408 Dryer - Gas
Maytag DG409 Dryer - Gas
Maytag DG410 Dryer - Gas
Maytag DG412 Dryer - Gas
Maytag DG412D Dryer - Gas
Maytag DG482 Dryer - Gas
Maytag DG482D Dryer - Gas
Maytag DG490 Dryer - Gas
Maytag DG490D Dryer - Gas
Maytag DG4910 Dryer - Gas
Maytag DG500 Dryer - Gas
Frigidaire DG500AXD5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXW5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500AXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500EXD1 Wwh(v16) / Gas Dryer
Frigidaire DG500EXD4 Wwh(v17) / Gas Dryer
Frigidaire DG500EXD5 Wwh(v18) / Gas Dryer
Frigidaire DG500EXF1 Wwh(v19) / Gas Dryer
Frigidaire DG500EXF4 Wwh(v20) / Gas Dryer
Frigidaire DG500EXF5 Wwh(v21) / Gas Dryer
Frigidaire DG500EXH1 Wwh(v22) / Gas Dryer
Frigidaire DG500EXH4 Wwh(v23) / Gas Dryer
Frigidaire DG500EXH5 Wwh(v24) / Gas Dryer
Frigidaire DG500EXV1 Wwh(v25) / Gas Dryer
  #2 (permalink)
Old 03-07-2013, 07:53 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Jstrand, You did purchase the motor kit, presumably,
Part number: AP5272724
A couple of quick update notes, The White wire(44) is the same as the grey wire on newer models(N), and should be attached to the 1/4" thermal protector tab. In order to maintain the circuit integrity, it's best to use the Electric Dryer (figure 4A) to wire the replacement motor, regardless of gas or electric dryer. The heat circuit on both units is black terminal 2 and blue terminal 1, on a gas machine when the motor starts and is running, the switch closes and completes the neutral circuit to the gas valve. You'll need to recheck and verify that the wires are attached to the proper terminals, and That the switch has a "closed" circuit between terminal 1 and 2 when the motor is running.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-07-2013, 08:41 AM
Junior Member
Default Maytag motor wiring
Yes I did purchase the motor kit and followed 4B wiring. Bottom line white (44) on 1/4" thermal with blue jumper to terminal 1, red on 5, black on 2, yellow on 6.
  #4 (permalink)
Old 03-07-2013, 08:55 AM
Senior Expert
Default
OK, now what you need to do is, disconnect the blue and black wire from terminals 1 and 2. tape or set them aside so they dont't get damaged. With the dryer power off check across the two terminals for an "open" circuit with a multi meter. Then start the dryer, and recheck across the no.1 and 2 terminals again, for a "closed" circuit. This will tell you if the centrifugal switch is completing the neutral circuit to the gas valve. If there is no circuit, presumably you'd have a faulty repalcement motor. You need to be careful, there will be 120 volts at other contacts of the motor.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer team301377 Dryer Repair 2 09-19-2011 04:19 AM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
maytag gas dryer burdell stuckey Dryer Repair 3 06-23-2010 12:07 PM
maytag dryer rmestig Dryer Repair 1 05-27-2009 03:20 PM
maytag dryer vitodipietra Dryer Repair 1 04-06-2009 07:03 AM
