Discuss
Maytag Dryer- won't heat - testing help please
 in
Dryer Repair
Hi, ran 8 loads of laundry yesterday. last load did not dry. we have checked the vent. no clogged or
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer- won't heat - testing help please
  #1 (permalink)
Old 02-04-2008, 08:25 PM
WCWRex WCWRex is offline
Junior Member
WCWRex is on a distinguished road
Unhappy Maytag Dryer- won't heat - testing help please
Model Number: LDE490   Brand: Maytag   Age: More than 10 years
ran 8 loads of laundry yesterday. last load did not dry. we have checked the vent. no clogged or plugs. no heat. there seems to be multiple possiblities..thermostat, heat coil, moisture sensor...etc.
is there a way to narrow the field. We have a testor as noted in other forums..but not sure how to go about with our model. I have the diagrams off your website..
any help or direction would be greatly appreciated. I hate to call out a repair person if I can narrow the field, so very expensive- my husband is very handy and can test most anything.
Thank you
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-05-2008, 03:38 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would make sure your power is 240 volts into the dryer, next pull the front panel and check the heater and wires to it, if bad, order a new one P# 303404
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag LSG7804AAE Dryer - Won't Heat Up HockeyDave Dryer Repair 4 02-14-2008 01:37 PM
Help with Maytag Dryer-won't heat up momto3 Dryer Repair 0 01-23-2008 09:54 AM
testing components mtrole Dishwasher Repair 0 12-07-2007 12:00 PM
maytag gas dryer will not heat after initial burn Agustin Dryer Repair 1 08-28-2007 10:48 AM
Fridge Thermostat Testing Tony.C Refrigerator & Freezer Repair 2 08-07-2007 01:31 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
