Dryer shutting down
I have a ge dryer that is shutting off after about 2-3 min it is getting hot maybe too hot. I have checked all thermistors and safetys. I will list what th e multi meter read in order from top of heat element housing starting from the left side as you look at the dryers front:
T-Stat Inlet safety 0 ohms Inlet thermistor 115k ohms Hi-Limit 0 ohms T-Stat Outlet back up org. 0 ohms Outlet Thermistor 112k ohms I belive that I have the correct names for each. I need to know what the correct readings are for each so I can get the correct part:confused: and if it is none of these I need more trouble shooting help:eek: !! Thanks!:) |
I forgot to say that I cleaned and checked all vent ducts they are all clean and clear and getting great air flow.
Parts for GE DPSB620EC4WW Dryer - AppliancePartsPros.com It is a GE so I will not be able to find any tech info (wiring diagram etc.) on it. Do you have the tech sheet. If not check in the control console to see if it is there. I am assuming that "shut off" means that the drum stops rotating. Your readings look OK to me. When it stops can you restart it right away? Or do you have to wait a while before it will restart? If you have to wait then the most likely cause is the motor over heating. It then trips it's internal thermal protect and you have to wait for the unit to cool down so the protect will reset. |
Quote:
I do not know if they monitor the thermistor readings and if they get out too far from each other the board shuts down.
Looks like they may us the hi-limit thermostat to power the motor. Try an air only cycle. Does it still shut down? Is there heat? If there is heat then you probably have a grounded element re: it has broken or sagged and is touching the case/frame in such a way that it is overheating the hi-limit. The way to check for a grounded element is to disconnect and measure across it, they are usually 10 to 30 ohms. Then measure from each heater connection to the frame or neutral, both should be infinite ohms. If using the frame be sure to find a spot with bare metal. This is for a 3 wire hook up with a 4 wire hook up you must check to the frame. |
Is there heat
Quote:
| All times are GMT -7. The time now is 12:22 PM. |
