Discuss
Gas dryer runs, won't heat. FIXED
 in
Dryer Repair
I wanted to post this in case it could help someone. I had a gas dryer that was running but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer runs, won't heat. FIXED
  #1 (permalink)
Old 10-02-2009, 07:40 PM
Junior Member
LA Daddy is on a distinguished road
Default Gas dryer runs, won't heat. FIXED
Model Number: 11076902692   Brand: Kenmore   Age: 5 - 10 years
I wanted to post this in case it could help someone. I had a gas dryer that was running but not heating (not glowing or igniting). After searching online, I found out it was likely the thermal fuse and thermostat. I called someone to repair it and they wanted to charge nearly $200 to replace the 2 parts and clean everything out.
I opted to try to save money and do it myself and I'm super glad I did. I ordered both parts on this site for $30 delivered. I got them the next day even though I chose the cheapest shipping option (I'm not far from their CA warehouse). It took me 15 minutes to replace and I'm really not that handy. I used a diagram I downloaded from ********************************.com which helped me find the part numbers and where they were in my dryer.
It was super easy so if you have the same problem I say try it yourself first. This should go without saying, but just make sure you unplug the dryer before you work on it to avoid electrocution.
Ads By Google
Related Models
Kenmore 11077401100 KENMORE GAS DRYER
Kenmore 11077401110 KENMORE GAS DRYER
Kenmore 11077401120 GAS DRYER
Kenmore 11077401400 KENMORE GAS DRYER
Kenmore 11077401410 KENMORE GAS DRYER
Kenmore 11077401420 GAS DRYER
Kenmore 11077401600 KENMORE GAS DRYER
Kenmore 11077401610 KENMORE GAS DRYER
Kenmore 11077401620 GAS DRYER
Kenmore 11077408160 GAS DRYER
Kenmore 11077408660 GAS DRYER
Kenmore 11077408860 GAS DRYER
Kenmore 11077409150 GAS DRYER
Kenmore 11077409650 GAS DRYER
Kenmore 11077409850 GAS DRYER
Kenmore 11077410100 KENMORE GAS DRYER
Kenmore 11077490100 KENMORE GAS DRYER
Kenmore 11077490200 KENMORE GAS DRYER
Kenmore 11077490400 KENMORE GAS DRYER
Kenmore 11077490600 KENMORE GAS DRYER
Kenmore 11077611100 KENMORE GAS DRYER
Kenmore 11077640100 KENMORE GAS DRYER
Kenmore 11077645100 KNEMORE GAS DRYER
Kenmore 11077675100 KENMORE GAS DRYER
Kenmore 11077675200 KENMORE GAS DRYER
Kenmore 11077675400 KENMORE GAS DRYER
Kenmore 11077675600 KENMORE GAS DRYER
Kenmore 11077732790 ELECTRIC DRYER
Kenmore 11077732791 GAS DRYER
Kenmore 11077732792 GAS DRYER
Kenmore 11077732794 GAS DRYER
Kenmore 11077732795 GAS DRYER
Kenmore 11077832790 ELECTRIC DRYER
Kenmore 11077832791 GAS DRYER
Kenmore 11077832792 GAS DRYER
Kenmore 11077832794 GAS DRYER
Kenmore 11077832795 GAS DRYER
Kenmore 11077834790 GAS DRYER
Kenmore 11077834791 GAS DRYER
Kenmore 11077834794 GAS DRYER
Kenmore 11077834795 GAS DRYER
Kenmore 11078202790 GAS DRYER
Kenmore 11078202794 GAS DRYER
Kenmore 11078202795 GAS DRYER
Kenmore 11078410100 KENMORE ELECTRIC DRYER
Kenmore 11078410110 KENMORE ELECTRIC DRYER
Kenmore 11078410200 KENMORE ELECTRIC DRYER
Kenmore 11078410210 KENMORE ELECTRIC DRYER
Kenmore 11078410400 KENMORE ELECTRIC DRYER
Kenmore 11078410410 KENMORE ELECTRIC DRYER
Kenmore 11078410600 KENMORE ELECTRIC DRYER
Kenmore 11078410610 KENMORE ELECTRIC DRYER
Kenmore 11078411100 KENMORE ELECTRIC DRYER
Kenmore 11078411110 KENMORE ELECTRIC DRYER
Kenmore 11078411200 KENMORE ELECTRIC DRYER
Kenmore 11078411210 KENMORE ELECTRIC DRYER
Kenmore 11078411400 KENMORE ELECTRIC DRYER
Kenmore 11078411410 KENMORE ELECTRIC DRYER
Kenmore 11078411600 KENMORE ELECTRIC DRYER
Kenmore 11078411610 KENMORE ELECTRIC DRYER
Kenmore 11078412100 KENMORE ELECTRIC DRYER
Kenmore 11078412200 KENMORE ELECTRIC DRYER
Kenmore 11078412400 KENMORE ELECTRIC DRYER
Kenmore 11078412600 KENMORE ELECTRIC DRYER
Kenmore 11078413100 KENMORE ELECTRIC DRYER
Kenmore 11078413200 KENMORE ELECTRIC DRYER
Kenmore 11078413400 KENMORE ELECTRIC DRYER
Kenmore 11078413600 KENMORE ELECTRIC DRYER
Kenmore 11078413800 KENMORE ELECTRIC DRYER
Kenmore 11078414100 KENMORE ELECTRIC DRYER
Kenmore 11078414200 KENMORE ELECTRIC DRYER
Kenmore 11078414400 KENMORE ELECTRIC DRYER
Kenmore 11078414600 KENMORE ELECTRIC DRYER
Kenmore 11078414800 KENMORE ELECTRIC DRYER
Kenmore 11078415100 ELECTRIC DRYER
Kenmore 11078415110 ELECTRIC DRYER
Kenmore 11078415120 ELECTRIC DRYER
Kenmore 11078415200 ELECTRIC DRYER
Kenmore 11078415210 ELECTRIC DRYER
Kenmore 11078415220 ELECTRIC DRYER
Kenmore 11078415400 ELECTRIC DRYER
Kenmore 11078415410 ELECTRIC DRYER
Kenmore 11078415420 ELECTRIC DRYER
Kenmore 11078415600 ELECTRIC DRYER
Kenmore 11078415610 ELECTRIC DRYER
Kenmore 11078415620 ELECTRIC DRYER
Kenmore 11078415800 ELECTRIC DRYER
Kenmore 11078415810 ELECTRIC DRYER
Kenmore 11078702890 ELECTRIC DRYER
Kenmore 11079082990 COMMERICAL GAS DRYER
Kenmore 11079202990 GAS DRYER
Kenmore 11079495100 KENMORE COMPACT GAS DRYER
Kenmore 11079495110 KENMORE GAS DRYER
Kenmore 11079495200 KENMORE COMPACT GAS DRYER
Kenmore 11079495210 KENMORE GAS DRYER
Kenmore 11079495400 KENMORE COMPACT GAS DRYER
Kenmore 11079495410 KENMORE GAS DRYER
Kenmore 11079495600 KENMORE COMPACT GAS DRYER
Kenmore 11079495610 KENMORE GAS DRYER
Kenmore 11079496100 SEARS KENMORE GAS DRYER
Kenmore 11079496110 KENMORE GAS DRYER
Kenmore 11079496200 SEARS KENMORE GAS DRYER
Kenmore 11079496210 KENMORE GAS DRYER
Kenmore 11079496400 SEARS KENMORE GAS DRYER
Kenmore 11079496410 KENMORE GAS DRYER
Kenmore 11079496600 SEARS KENMORE GAS DRYER
Kenmore 11079496610 KENMORE GAS DRYER
Kenmore 11079812990 GAS DRYER
Kenmore 11079902890 GAS DRYER
Kenmore 11079912990 GAS DRYER
Kenmore 11080094 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE
Kenmore 11080252 DOLE MIXING VALVE ASSEMBLY
Kenmore 11080364 MIXING VALVE ASSEMBLY
Kenmore 11080609 MIXING VALVE ASSEMBLY
Kenmore 11080671 MIXING VALVE ASSEMBLY
Kenmore 11080754000 WASHER-DRYER LAUNDRY SYSTEM
Kenmore 11080754001 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11080764000 WASHER-DRYER LAUNDRY SYSTEM
Kenmore 11080881 FULTON SYLPHON MIXING VALVE ASSEMBLY
Kenmore 11080947 MIXING VALVE ASSEMBLY
  #2 (permalink)
Old 10-03-2009, 03:59 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
That is super.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Gas Dryer Runs, but no heat OKCandy Dryer Repair 10 04-18-2009 04:48 PM
Dryer runs but will not heat up freezer65 Dryer Repair 0 07-04-2008 12:26 PM
Dryer Runs but no heat Charlied Dryer Repair 0 07-03-2008 05:16 PM
Dryer runs but want heat gidget Dryer Repair 0 02-02-2008 10:40 AM
