Discuss
Frigidaire Stacker - The Dead Bionic Dryer! (not better stronger or faster)
 in
Dryer Repair
Well, I finally got the correct wiring harness and replaced the fried wiring harness in the unit, and carefully put
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Stacker - The Dead Bionic Dryer! (not better stronger or faster)
  #1 (permalink)
Old 03-01-2013, 02:56 PM
Junior Member
markmawn is on a distinguished road
Default Frigidaire Stacker - The Dead Bionic Dryer! (not better stronger or faster)
Model Number: FEZ831AS1   Brand: Frigidaire   Age: 5 - 10 years
Well, I finally got the correct wiring harness and replaced the fried wiring harness in the unit, and carefully put the dryer back together. When I plugged it, turned on the power and hit the start button on the drier....Nothing! If I hold down the start button, there is a clicking, so I know power is connecting to the panel. However, the motor is not coming on, nor the heat element. (Washer is working fine, BTW)
To give this unit some recent history, here are the recent parts I purchased and repaired.
Blower wheel: part# 131476300
-> The old wheel was melted to the blower compartment which prevented the motor from turning, which possibly lead to the wires melting leading to the heater element
Rear drum bearing kit: part# 5303281153
-> This needed to be replaced since the original plastic part was melted around the wheel, though the wheel was able to turn despite this before.
Harness - lcd main elec: part# 134119400
-> This replaced the melted wires leading from the motor to the heating element.
Where I am at now...
All of the above was carefully put back into place. The blower wheel can be turned by hand when attached to the motor.
Questions:
1) What ELSE could cause the power not to come on for the drier?
2) Did the fuse get fried? The wiring up to the heating element and the fuse were melted, and half way down the harness. No other melting anywhere else.
Rather than continue on an seemingly endless quest that may eventually lead to me replacing every single part in the machine, please let me know what the next steps should be, including testing, etc.
Many thanks and I appreciate the responses so far!
Mark
Related Models
Frigidaire FEZ831AS1 Lc - Frigidaire
Frigidaire FEZ831AS2 Frigidaire/laundry Center
Frigidaire FEZ831CFS0 Frigidaire/laundry Center
Frigidaire FEZ831CFS1 LAUNDRY CENTER
Amana FF105 REF - BOTTOM MOUNTS
Amana FF105A REF - BOTTOM MOUNTS
Amana FF105B REF - BOTTOM MOUNTS
Amana FF105L REF - BOTTOM MOUNTS
Amana FF105LA REF - BOTTOM MOUNTS
Amana FF105LB REF - BOTTOM MOUNTS
Amana FF125 REF - BOTTOM MOUNTS
Amana FF125A REF - BOTTOM MOUNTS
Amana FF125B REF - BOTTOM MOUNTS
Amana FF125L REF - BOTTOM MOUNTS
Amana FF125LA REF - BOTTOM MOUNTS
Amana FF125LB REF - BOTTOM MOUNTS
Amana FF15 FREEZER- VERTICAL
General Electric FF16DSARWH Refrigerator
General Electric FF16DSBRWH Refrigerator
General Electric FF16DSCRWH Refrigerator
General Electric FF16DSDRWH Refrigerator
General Electric FF16DSERWH Refrigerator
General Electric FF16DXARWH Refrigerator
General Electric FF16DXBRWH Refrigerator
General Electric FF16DXCRWH Refrigerator
General Electric FF20DSARWH Refrigerator
General Electric FF20DSBRWH Refrigerator
General Electric FF20DSCRWH Refrigerator
General Electric FF20DSDRWH Refrigerator
General Electric FF20DSERWH Freezers
General Electric FF20DXARWH Refrigerator
General Electric FF20DXBRWH Refrigerator
General Electric FF20DXCRWH Refrigerator
Amana FF98 REF - BOTTOM MOUNTS
Amana FF98A REF - BOTTOM MOUNTS
Amana FF98B REF - BOTTOM MOUNTS
Amana FF98L REF - BOTTOM MOUNTS
Amana FF98LA REF - BOTTOM MOUNTS
Amana FF98LB REF - BOTTOM MOUNTS
Frigidaire FFBD1821MB0A DISHWASHER
Frigidaire FFBD1821MS0A DISHWASHER
Frigidaire FFBD1821MW0A DISHWASHER
Frigidaire FFBD2403LB0A DISHWASHER
Frigidaire FFBD2403LB0B DISHWASHER
Frigidaire FFBD2403LS0B DISHWASHER
Frigidaire FFBD2403LW0A DISHWASHER
Frigidaire FFBD2403LW0B DISHWASHER
Frigidaire FFBD2405KB0 DISHWASHER
Frigidaire FFBD2405KB0A DISHWASHER
Frigidaire FFBD2405KS0 DISHWASHER
Frigidaire FFBD2405KS0A DISHWASHER
Frigidaire FFBD2405KW0 DISHWASHER
Frigidaire FFBD2405KW0A DISHWASHER
Frigidaire FFBD2407LB0A DISHWASHER
Frigidaire FFBD2407LB0B DISHWASHER
Frigidaire FFBD2407LM0A DISHWASHER
Frigidaire FFBD2407LM0B DISHWASHER
Frigidaire FFBD2407LQ0A DISHWASHER
Frigidaire FFBD2407LQ0B DISHWASHER
Frigidaire FFBD2407LS0A DISHWASHER
Frigidaire FFBD2407LS0B DISHWASHER
Frigidaire FFBD2407LW0A DISHWASHER
Frigidaire FFBD2407LW0B DISHWASHER
Frigidaire FFBD2409LB0A DISHWASHER
Frigidaire FFBD2409LM0A DISHWASHER
Frigidaire FFBD2409LQ0A DISHWASHER
Frigidaire FFBD2409LS0A DISHWASHER
Frigidaire FFBD2409LW0A DISHWASHER
Frigidaire FFC04M0AW1 Frigidaire/freezer
Frigidaire FFC0513D Frigidaire/freezer
Frigidaire FFC0522DW0 Frigidaire/freezer
Frigidaire FFC0522DW1 Frigidaire/freezer
Frigidaire FFC0522DW10 FREEZER
Frigidaire FFC0522DW11 FREEZER
Frigidaire FFC0522DW12 FREEZER
Frigidaire FFC0522DW13 FREEZER
Frigidaire FFC0522DW14 FREEZER
Frigidaire FFC0522DW15 FREEZER
Frigidaire FFC0522DW16 FREEZER
Frigidaire FFC0522DW17 FREEZER
Frigidaire FFC0522DW18 FREEZER
Frigidaire FFC0522DW19 FREEZER
Frigidaire FFC0522DW2 Frigidaire/freezer
Frigidaire FFC0522DW20 FREEZER
Frigidaire FFC0522DW3 Frigidaire/freezer
Frigidaire FFC0522DW4 Frigidaire/freezer
Frigidaire FFC0522DW5 Frigidaire/freezer
Frigidaire FFC0522DW6 Frigidaire/freezer
Frigidaire FFC0522DW7 FREEZER
Frigidaire FFC0522DW8 FREEZER
Frigidaire FFC0522DW9 FREEZER
Frigidaire FFC0522FW0 Frigidaire/freezer
Frigidaire FFC0522FW1 FREEZER
Frigidaire FFC0522FW2 FREEZER
Frigidaire FFC0522FW3 FREEZER
Frigidaire FFC0522FW4 FREEZER
Frigidaire FFC0522FW5 FREEZER
Frigidaire FFC0522FW6 FREEZER
Frigidaire FFC0522FW7 FREEZER
Frigidaire FFC0522FW8 FREEZER
Frigidaire FFC0522FW9 FREEZER
Frigidaire FFC0522GB0 Frigidaire/freezer
Frigidaire FFC0522GB1 FREEZER
Frigidaire FFC0522GB5 FREEZER
Frigidaire FFC0523DW0 Frigidaire/freezer
Frigidaire FFC0523DW1 Frigidaire/freezer
Frigidaire FFC05C2AW0 Frigidaire/freezer
Frigidaire FFC05C2AW1 Frigidaire/freezer
Frigidaire FFC05C3CW0 Frigidaire/freezer
Frigidaire FFC05C3CW1 Frigidaire/freezer
Frigidaire FFC05C3CW2 Frigidaire/freezer
Frigidaire FFC05C3CW3 Frigidaire/freezer
Frigidaire FFC05C4CW0 Frigidaire/freezer
Frigidaire FFC05K0AW0 Frigidaire/freezer
Frigidaire FFC05K0AW1 Frigidaire/freezer
Frigidaire FFC05K0DW0 Frigidaire/freezer
Frigidaire FFC05K0DW1 Frigidaire/freezer
Frigidaire FFC05K0DW2 Frigidaire/freezer
Frigidaire FFC05K0DW3 Frigidaire/freezer
Frigidaire FFC05K0DW4 Frigidaire/freezer
  #2 (permalink)
Old 03-01-2013, 06:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mark,
Check for continuity the thermal limiter (#36 at the diagram). Replace if it's open.
- The thermal limiter Part number: 134120900
Here are the breakdown diagrams and Parts for Frigidaire FEZ831AS1 Washer Dryer Combo - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire stacker issues ewcutter Washer Repair 0 12-28-2012 09:49 AM
Stacker Dryer TRANTAM Dryer Repair 0 09-26-2011 07:03 PM
huebsch stacker dryer cary goody Dryer Repair 0 12-07-2010 11:22 AM
Stacker Dryer will not Dry Clothes cvm Dryer Repair 1 05-21-2009 05:11 AM
Frigidaire stacker combo washer drains out while filling BT5150 Washer Repair 1 05-03-2009 01:15 PM
