My dryer element burned out and broke.. I replaced it. When it burned out it melted the bearing so I replaced it along with the belt. Still does not work. With the door removed and the door switch shorted I can turn the "on" switch and hear the timer motor running in 2 of the 3 heating settings. It goes off when I release the swith. The motor does not turn. The door switch checks out okay and the tow tow thermal switches near the heating element also check out. Will a partially worn out control/timer cause the machine to not worka at all? Is ther a fuse of some sort I am missing that may have blown when the heating ellement blew? Thanks
