Hi Thankyou in advance.
The dryer stopped drying a couple years ago, switched to another one. Would like to get this one working. As I explored circuit, uncovered that we had power on the typical neutral (wire). Changed outlet. The dryer died about the same time we had a new service put in. It had a ground wire attached, did not after service change, does now. and it turns out the cord internally is wired backwards as well. Will be looking at house wiring next. Does the polarity to the valve coils make a difference, or anything else.
