jodani95
#1 Posted : Sunday, February 24, 2013 12:29:10 PM(UTC)
jodani95
We get a pf code and then intermittent it will give a number indicating how ling the cycle will run for..but does not start..we have changed the circuit box since we were unsure if this was the same problem to our water heater, which fixed the water problem..we held in start button for 5 seconds and no change..we also have changed the thermister with no luck in getting it to run...no blockages in vent either...please help, cannot afford a tech to come out!!!
#2 Posted : Monday, February 25, 2013 12:02:39 PM(UTC)
Hello,
Remove the toe panel and check the belt and the broken belt switch (under the idler pulley).
- The belt Part number: 661570
Part number: 661570
- The belt switch Part number: 279782
jodani95
#3 Posted : Monday, April 1, 2013 5:04:04 PM(UTC)
jodani95
Thxs Gene, the belt appears ok as well. Any other suggestions??
#4 Posted : Thursday, April 4, 2013 9:58:45 AM(UTC)
Sorry for the delay.
Remove the top cover to access the main control board (#57 at the diagram). Check for 120 VAC between the wires connected to the terminals P1-2 & P1-5 at the control board.
If the reading is correct, close the door ans check for 120 VAC between the wires connected to the terminals P1-5 & P1-3.
If the reading is correct, set the dry cycle, push the start button and check for 120 VAC between the wire connected to the terminal P1-2 and the terminal P1-4 at the control board. If the reading is incorrect, replace the control board.
- The control board Part number: 8546219
Can't get pass PF code error display (Dryer Repair)
by gman536 3/15/2021 5:51:27 AM(UTC)
PF code (Power Failure) on clock will not reset (Oven Repair (including Ranges and Cooktops))
by lmevans 12/9/2012 2:26:02 PM(UTC)
Low pressure, stalling during cycle, PF code (Dishwasher Repair)
by agast 9/11/2012 12:13:19 PM(UTC)
Kenmore Gas Range PF code won't reset (Oven Repair (including Ranges and Cooktops))
by mklindsey 2/20/2012 5:40:08 PM(UTC)
pf code won't drain (Dishwasher Repair)
by desanto 2/18/2012 4:55:06 AM(UTC)
Pf Code Will Not Reset (Oven Repair (including Ranges and Cooktops))
by tleslie 12/12/2010 8:31:07 AM(UTC)
pf code (Oven Repair (including Ranges and Cooktops))
by frogetit 10/15/2009 6:47:48 AM(UTC)
PF Code and no buttons working on whirpool gold (Oven Repair (including Ranges and Cooktops))
by Emilykai 10/14/2009 2:51:22 PM(UTC)
Whirlpool Oven/Mwave Combo PF Code (Oven Repair (including Ranges and Cooktops))
by jimbouk15 6/27/2009 2:56:24 PM(UTC)
kenmore electric range pf code and top element in oven stays on always (Oven Repair (including Ranges and Cooktops))
by closs2sx 1/6/2009 5:32:12 AM(UTC)
pf codes (Oven Repair (including Ranges and Cooktops))
by Ben Mc Daniel 5/29/2008 6:40:50 PM(UTC)
Kenmore Oven throwing PF codes (Oven Repair (including Ranges and Cooktops))
by mgeubtn 5/29/2008 3:40:37 PM(UTC)
