gas valve coils
I,m trying to replace the coils on the gas valve for this dryer. There are 3 coils and two valves. I know which 2 of the 3 coils go together and which one stands alone. The problem is I don't which coils go to which valve. I would appreciate any help on this. Thanks
What are the part numbers of the coils you are trying to install?
Do they have a wires attached or just terminals? Gene. |
Dryer gas valve coils
Quote:
Where did you find them? Such coils have been no longer available for long time. Are you sure this is correct part?
According to the manufacturer instructions the whole gas valve and burner assembly has to be replaced if coils are bad. - The gas valve assembly Part number: AP3094285 Gene. |
The coils part # 279137 were bought at Dey appliance in Mpls.
Joe 209. |
Quote:
Gene. |
| All times are GMT -7. The time now is 12:20 PM. |
