Discuss
Pretty sure my Kenmore is possessed!
 in
Dryer Repair
It all started out with the dryer mysteriously shutting down half way through a cycle, then this problem cleared up
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Pretty sure my Kenmore is possessed!
  #1 (permalink)
Old 02-19-2013, 07:17 PM
Junior Member
1wetmonkey is on a distinguished road
Default Pretty sure my Kenmore is possessed!
Model Number: 417.996802180   Brand: Kenmore   Age: More than 10 years
It all started out with the dryer mysteriously shutting down half way through a cycle, then this problem cleared up for a while. Then i noticed the motor was struggling. Running then quitting for a second, then would continue running. I took it all apart and cleaned it out, it was great again for weeks. This morning it quit working all together. I started a load in the washer tonight, and now the drier works fine. If I shut off the dryer the washer quits, and if I turn off the washer the dryer quits. Help!
Ads By Google
Related Models
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
  #2 (permalink)
Old 02-20-2013, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Sounds like there is something wrong with the power supply for the unit or there is something wrong with wire connections inside the unit.
Remove the access panel between the washer and the dryer and look for the technical documentation in an envelope. Check the wiring harness plug between the washer and the dryer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore ultra wash possessed rlyons124 Dishwasher Repair 4 04-20-2011 11:28 AM
just fixed (pretty well) handle of JVM1490WD003 GE profile spacemaker microwave amontillado Microwave Repair 1 02-07-2010 03:37 PM
Possessed Fan Kalburgi Oven Repair (including Ranges and Cooktops) 0 02-23-2008 01:59 PM
