Discuss
dryer starts but heat cycle trips breaker
 in
Dryer Repair
Gas Dryer starts fine if you set for no heat or air dry. As soon as you switch to call
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer starts but heat cycle trips breaker
  #1 (permalink)
Old 02-19-2013, 06:15 PM
Junior Member
dad14 is on a distinguished road
Default dryer starts but heat cycle trips breaker
Model Number: 110.92822101   Brand: Kenmore   Age: 5 - 10 years
Gas Dryer starts fine if you set for no heat or air dry. As soon as you switch to call for heat, it trips breaker. Definitely not motor related. Looking for ideas what to try.
Ads By Google
Related Models
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
  #2 (permalink)
Old 02-20-2013, 04:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Plug the dryer in a different outlet and run it to make sure there is nothing wrong with the circuit breaker. I hope you did not use a GFCI breaker.
Remove the top panel and locate the control board on the left side. Remove the Red wire from the heater relay at the control board and give it a try.
If the breaker will go Off, replace the control board.
- The control board Part number: 8546219
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-21-2013, 05:32 PM
Junior Member
Default
Gene, thanks for the suggestions. I had already tried a different outlet and it responded the same. I tried removing the red wire on control board and yes it runs without throwing breaker. Are you fairly certain I shouldn't look any further and that is the problem for sure? I also did ohm check on gas control coil and it checked out OK.
  #4 (permalink)
Old 02-27-2013, 10:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry for the delay.
The instruction I posted earlier is incorrect because of mistyping. Instead of: "If the breaker will stay On, replace the control board" it should be "If the breaker goes Off, replace the control board".
Check for continuity between that Red wire and the ground and post the result.
I attached the wiring sheet for this dryer. It might help too.
File Type: pdf Wiring Sheet - 3976605 - 11092822101.pdf (296.2 KB, 1 views)
__________________
  #5 (permalink)
Old 02-28-2013, 05:41 AM
Junior Member
Default
Oh that stinks. Yes it was staying on not tripping the breaker after removing the red wire so I guess my problem is elsewhere. Am I removing red wire and ground from the control board and then checking for continuity between them?
  #6 (permalink)
Old 02-28-2013, 09:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by dad14 View Post
...Am I removing red wire and ground from the control board and then checking for continuity between them?...
Yes, you can do it this way or you can use any dryer metal surface as ground.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer on heat setting trips breaker immediately lightninskyhop Dryer Repair 0 06-06-2012 11:45 PM
Kenmore washer won't drain, starts spin cycle stops trips circuit breaker m789h Washer Repair 6 01-14-2011 06:38 PM
trips breaker during cool down cycle extagger Dryer Repair 1 07-28-2010 04:21 AM
gas dryer trips breaker when rying to heat garrywith2rz Dryer Repair 1 09-30-2009 05:08 PM
Trips breaker on slow cycle candu Washer Repair 2 12-18-2008 05:37 PM
