Discuss
my dryer won't start
 in
Dryer Repair
called cust. service and was suggested I get a new timer. It's not the timer. When I press start the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » my dryer won't start
  #1 (permalink)
Old 02-19-2013, 03:50 PM
Junior Member
susanpoole is on a distinguished road
Default my dryer won't start
Model Number: pye4557ayw   Brand: Maytag   Age: 5 - 10 years
called cust. service and was suggested I get a new timer. It's not the timer. When I press start the dryer makes the humming sound like it's going to start, lasts maybe 3-5 seconds, and then there's a click sound and then nothing... kind of like a gfci switch tripping. if I try and restart immediately nothing happens. If I wait a bit, I get the same hum-click. Any suggestions? I took the machine apart, cleaned everything, checked all the connections. I did install the new timer but the same thing was happening so I reinstalled the old one. And...the dryer started. ran 2 loads and then the above happened.
Ads By Google
Related Models
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
Whirlpool R183F0
Whirlpool R183G0
Whirlpool R183G1
Amana R1E Mwave - Family Size (60 Hz)
Jenn-Air R200 Surface Unit - Ddraft Ele
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
  #2 (permalink)
Old 02-21-2013, 02:12 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Maytag PYE4557AYW Dryer - AppliancePartsPros.com
Sounds like the motor is toast.
When it does not start it overheats and trips it's internal thermal protect.
You then have to wait for it to cool down so that the thermal protect resets before it will try to start again.
Perhaps try the following to confirm that it is the motor.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
  #3 (permalink)
Old 02-21-2013, 04:21 AM
Junior Member
Default
ok, thanks. it's not lint so I'll try the drum test. I just looked up the motor part and it's listed as out of stock.....now what???
  #4 (permalink)
Old 02-21-2013, 04:43 AM
Senior Expert
APP Volunteer
Default
If it turns out to be the motor give them a call and see when if ever the motor will be available. You could also try local parts supply dealers.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
