| » Full Front Panel Removal |
Model Number: 110.67082600 Brand: Kenmore Age: 1 - 5 years
How do I remove the full front panel of Kenmore Elite Oasis Canyon Dryer Model 110.67082600 to remove any accumulated lint in cabinet? I would appreciate step by step instructions, if available. Thank you.
Hi.
Use a putty knife to open the two clips holding the top (one in each corner), lift the top, take out two screws holding the front from inside, lift the front an inch and remove it. To remove the bulkhead take out the 4 screws at the bottom and loosen up 2 at the top. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Do I need to remove the console and/or top panel first? I noticed the brackets on the rear of the machine are not hinged. Do I run the risk of cracking or breaking them without removing them? Thank you. |
You should be able to raise the top (according the manual).
If you are not sure, just be careful. Simon.
__________________
| Display Modes | |
| Broken Knob requires full front panel purchase? | Momojo | Washer Repair | 1 | 05-31-2011 05:51 PM |
| GE front panel removal | blevdog | Washer Repair | 1 | 05-18-2011 06:00 PM |
| front panel removal | bobets2@tds.net | Washer Repair | 2 | 11-17-2010 02:14 PM |
| front panel removal | bobets2@tds.net | Washer Repair | 1 | 11-17-2010 02:06 PM |
| front panel removal | DREW255 | Washer Repair | 5 | 10-01-2008 08:06 PM |
