| » washer |
Model Number: wdsr2080d5ww Brand: GE Age: 5 - 10 years
the washer rotary start switch moves and i cane here it running but nothing happens when i turn the knob by hand the drum starts going and then stops i checked the pump mooter with a ohm miter and got a good rating
HI.
Please explain clearly what is the problem with the washer.Be more detailed. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
when i start the washer it will fill up and drum will run but it will not go into spin cycle and the water will not pump out i put a miter to the pump and got a good reading even when i turn the knob to spin and drain nothing happens i took the drain hose and put it to the floor some water came out and then stoped
Hi.
Does the washer agitates? Does the motor runs when washer is in the spin? Check if there is 120VAC at the drain pump contacts when timer set for drain. Simon.
__________________
| Display Modes | |
