| » Maytag Neptune Dryer not starting |
Model Number: MCE8000AYW Brand: Maytag Age: 5 - 10 years
I have a Maytag Neptune dryer model MCE8000AYW. It will not start.
When I press the Start button, it just makes a clicking sound. The top portion of the drying cabinet works fine. The control panel works and the diagnostic code result returns SOL and End (nothing). I ran a Logic Board Output Self-Test (Lo) and both top and bottom return PASS. We reset to factory defaults and still nothing. I opened the front case, cleaned out all the lint. I removed the Thermal fuse and tested for continuity and there is continuity. I put the thermal fuse back on. I also tested the door switch and the continuity was also good. Any other testing suggestions or help would be appreciated. Thank you, Buckeye 597 Ads By Google Related Models |
| Display Modes | |
| Need help with old Maytag dryer not starting | momkaren | Dryer Repair | 1 | 09-15-2012 08:27 AM |
| Maytag Atlantis Dryer not starting | herb191 | Dryer Repair | 5 | 12-19-2011 09:15 AM |
| Maytag Electric Dryer Not Starting | jsoika | Dryer Repair | 0 | 11-12-2011 12:12 PM |
| Maytag Dryer Not Starting | Wynnfidel | Dryer Repair | 1 | 04-08-2011 05:28 PM |
| Maytag Dryer Noisy when starting | jpw050 | Dryer Repair | 3 | 05-25-2010 03:24 PM |
