| » Maytag Dryer Code SE |
Model Number: MDE2400AYW Brand: Maytag Age: 5 - 10 years
I have a stackable Maytag Dryer that is working , but not drying well.
It shows a code of SE - or maybe it is 5E - and I cannot find any info on this. Any help is appreciated! Ads By Google Related Models |
Hi.
Sorry. Was not able to locate the diagnostic codes for this model. But I'd recommend you to check the air flow trough the dryer and entire vent to the outside for the restrictions. Also check the thermistor. Locate the 6 pins/4 wires plug at the control board and check the resistance between R and WH. At room temp. - 60Kohm. Here are the breakdown diagrams and 02-Cabinet parts for Maytag MDE2400AYW - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hello,
There are no error codes listed for this model. If the problem is longer time to dry then I would suggest to clean the dryer and the vent line. You also may want to check the thermistor (on the blower housing). The normal reading is 60K ohms at the room temperature. - The thermistor Part number: 35001056 Here are the breakdown diagrams and Parts for Maytag MDE2400AYW Dryer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
We checked the Termistor, THOROUGHLY cleaned the dryer andexhaust vent, all parts "seem" to be ok with meter. But it only heats to 100 deg F. Any ideas? |
What is the serial number of the dryer?
Where is the dryer located and what is the ambient temperature? Remove the thermistor and check if it has a silicone rubber boot at the sensing bulb. If it does then remove that boot and give it a try. Gene
__________________
| Display Modes | |
| Maytag Neptune Dryer Code FE | hamrepairman | Dryer Repair | 7 | 07-10-2012 07:05 PM |
| Maytag Neptune Gas Dryer Error Code E5 | tthomas1020 | Dryer Repair | 0 | 03-07-2010 09:14 AM |
| Maytag Neptune Dryer Code | DOC DAVE | Dryer Repair | 1 | 01-21-2009 02:35 PM |
| Maytag Dryer Repair Code F43 | GKHARMON | Dryer Repair | 1 | 01-13-2009 02:06 PM |
| F22 error code on maytag bravos dryer | heatherj | Dryer Repair | 0 | 10-27-2007 07:19 PM |
