Discuss
Kenmore HE2 won't shut off in Auto Cycles
 in
Dryer Repair
Our dryer is not turning off in the Auto cycle. The display doesn't show "Wet" at first. Then eventually it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore HE2 won't shut off in Auto Cycles
  #1 (permalink)
Old 02-10-2013, 12:37 PM
Junior Member
PHRoberts is on a distinguished road
Default Kenmore HE2 won't shut off in Auto Cycles
Model Number: 110.97562601   Brand: Kenmore   Age: 5 - 10 years
Our dryer is not turning off in the Auto cycle. The display doesn't show "Wet" at first. Then eventually it will show "Damp" and sort of freeze with about 11 or 12 minutes left on the countdown timer.
A week or two ago, my wife dried a particularly fuzzy blanket that overloaded the lint trap. I took the cover off that contains the lint trap and mositure sensor bars and vacuumed everything out. I'm 95% sure I put the two wires back on the correct elements when I reconnected the bars (if that even maters).
I just took it apart again to see if I left a connection loose, and checked the bars with a multimeter. They check open with nothing touching them, and somewhere around 200K ohms (numbers jump around quite a bit) with a moistened finger across them - so I think the bars are OK, but I really have no idea what the specification is.
I see some mention of a diagnostic mode on other sites but the pictures are really small, and when I try to zoom on them they blur to the point that they can't be read.
Any suggestions?
Thanks!
Heath
Ads By Google
Related Models
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
  #2 (permalink)
Old 02-11-2013, 02:50 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
See the attachment for a better quality tech sheet.
__________________
  #3 (permalink)
Old 02-11-2013, 10:04 AM
Junior Member
Default
Quote:
Thank you very much denman! The moisture sensor test beeps when I touch the moisture bars and flashes "CO" on the display. I also checked the MOVs using test 4 and everything checks open as it should.
Could hooking up the connections to the moisture sensor backwards cause an issue? I wouldn't think so, but I don't know for sure?
Heath
  #4 (permalink)
Old 02-11-2013, 01:45 PM
Senior Expert
APP Volunteer
Default
I also believe that switching the wires should not make a difference.
You could try unplugging it at the control board.
This would simulate a dry clothes status.
Then if it does not advance odds are that the control board needs replacing.
__________________
  #5 (permalink)
Old 02-11-2013, 01:51 PM
Junior Member
Default
Will do.
I'm guessing the MOVs are in the circuit to keep static electricity from the rotating clothes from frying the board? I don't know much about them, but I remember MOVs being in a circuit for motor drive controllers on the old big dish satelite systems my dad installed back in the 1980s. They would go bad after a lightning strike, but everything would still work - then the next big storm would blow the top off of the chips in the now unprotected controller. He eventually started installing trailer hitch plugs in the wiring between the controller and arm so that the homeowner could unplug the wiring during a storm if they were home.
Thanks again for your help!
Heath
  #6 (permalink)
Old 02-11-2013, 11:23 PM
Junior Member
Default
Well... just for fun, I reversed the connections on the moisture sensor and it worked correctly. It took about 50 minutes for an automatic drying cycle in the "normal" setting that started out with a 40 minute estimate.
To test my theory I swapped the wires back, and on the next cycle it hung up at 7 minutes left on the countdown timer and ran for about 65 minutes before I stopped the dryer manually.
Swapped them back for the next load and it worked again.
So either I have an intermittent problem, or that cured it. If it works for a few months I'll feel better about it.
For anyone reading this in the future, the "correct" wiring at the sensor seems to be black wire on the bottom bar, yellow/red on the top.
Heath
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
auto cycles wont dry ddpete Dryer Repair 1 12-11-2011 09:57 AM
Amana Dryer will not stop on Auto Cycles Tmcjury Dryer Repair 1 01-26-2011 06:45 PM
auto shut-down after 3-5 seconds lovenaz1940 Dishwasher Repair 4 05-07-2010 06:49 AM
auto sensing setting won't shut off chuckkapl Dryer Repair 1 04-22-2010 04:40 AM
dryer timer auto cycles don't work mikedudl Dryer Repair 0 04-29-2008 09:52 AM
