| » Dryer Takes To Long To Dry |
Model Number: LE4440XWW0 Brand: Whirlpool Age: 5 - 10 years
I just ordered a Heater Element another Thermostat (this dryer has 3) a Thermal Fuse and a new Blower Wheel (just in case). It has been suggested that the Blower Wheel may not be remaining engaged due to wear and the age of the machine. 02/11/2013 - Yesterday I replaced the Thermal Fuse and that did not repair the problem. I did discover when I went into the bulkhead alot of lint - AND as I first guessed the Rear Drum Felt Seal is shot, causing all the lint to get inside the bulkhead and not properly vent outside. I understand this is a common problem with older machines and should be looked at. The seal was dryrotted, cracked and in some places missing (hense the large amount of lint). Next step replace the seal and return all the extra parts I ordered. Ads By Google Related Models Last edited by Mhenry3 : 02-11-2013 at 10:08 AM. Reason: Adding more info |
Hi.
Check the connections at the terminal block at the back of the dryer where the power cord is attached. Run the normal load of clothes without the vent connected to the dryer. Did you take out and clean the lint chute? (It's the lint filter housing.) Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Please, let us know the results.
Simon.
__________________
| Display Modes | |
| Dryer takes too long to dry | so2315 | Dryer Repair | 0 | 07-26-2011 12:30 PM |
| dryer takes too long to dry | mark stevenson | Dryer Repair | 0 | 05-03-2011 09:46 PM |
| dryer takes too long | LEE128 | Dryer Repair | 1 | 11-28-2009 06:38 PM |
| Dryer Takes Too Long... | DjonesAX | Dryer Repair | 4 | 10-25-2008 10:34 AM |
| Dryer takes to long to dry | Julito | Dryer Repair | 1 | 12-05-2007 12:10 PM |
