Discuss
Maytag electric dryer won't heat
 in
Dryer Repair
Well I started digging around, found the schematic and diagram in the control panel. I've got voltage from L2 to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag electric dryer won't heat
  #11 (permalink)
Old 02-24-2013, 10:51 AM
Junior Member
Telicoman is on a distinguished road
Default
Well I started digging around, found the schematic and diagram in the control panel. I've got voltage from L2 to pin 2 on the drive motor and voltage from L1 making it all the way through the heater to pin 1 on the drive motor and I'm guessing the centrifugal switch refuses to close.
  #12 (permalink)
Old 02-26-2013, 01:45 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag MDE7600AYW Dryer - AppliancePartsPros.com
The motor pins are not marked on the schematic so I have to do some guessing.
Using 120 volts to check for no heat can be confusing as the 120 can feed through various parts and you have no wat of knowing whether you are measuring L1 or L2 voltage.
Check L1 to L2 at the terminal strip, it should be 240 volts.
Then check across the motor's heater centrifugal switch, it also should be 240 volts.
if yes then the switch is the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag electric dryer heat stays on SusanMKoehler@comcast.net Dryer Repair 3 06-28-2016 07:09 AM
Maytag Electric Dryer won't heat up rajpat25 Dryer Repair 8 08-27-2012 08:51 AM
No heat in Maytag Electric dryer mikecohrs Dryer Repair 6 02-26-2011 05:51 AM
Maytag Electric Dryer Won't Heat ayersl Dryer Repair 7 02-26-2010 03:09 PM
Maytag Performa Electric Dryer No Heat linktlife Dryer Repair 7 11-03-2009 04:07 PM
