Discuss
Electric Whirlpool Dryer - no Heat!
 in
Dryer Repair
Bought new heating element about 3 months ago. It worked great. Now - no heat. It runs no problem, just
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric Whirlpool Dryer - no Heat!
  #1 (permalink)
Old 02-05-2013, 11:51 AM
Junior Member
willow5000 is on a distinguished road
Unhappy Electric Whirlpool Dryer - no Heat!
Model Number: LER8648PWO   Brand: Whirlpool   Age: 1 - 5 years
Now - no heat. It runs no problem, just doesn't heat.
After the heat went out, it came back the next day (but not as hot as usual), and today there is nothing at all.
What do I check? what could be the culprit?
thanks
Ads By Google
Related Models
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
Whirlpool LET7646DZ0
Whirlpool LET7646DZ1
Whirlpool LET7646EQ0
Whirlpool LET7646EQ1
Whirlpool LET7646EQ2
Whirlpool LET7646EZ0
Whirlpool LET7646EZ1
Whirlpool LET7646EZ2
Whirlpool LET7848AN0
Whirlpool LET7848AQ0
Whirlpool LET7848AQ1
Whirlpool LET7848AQ2
Whirlpool LET7848AW0
Whirlpool LET7848AZ0
Whirlpool LET7848AZ1
Whirlpool LET7848AZ2
Whirlpool LET7848DQ0
Whirlpool LET7848DQ1
Whirlpool LET7848DZ0
Whirlpool LET7848DZ1
Whirlpool LET8858AN0
Whirlpool LET8858AN1
Whirlpool LET8858AN2
Whirlpool LET8858AQ0
Whirlpool LET8858AQ1
Whirlpool LET8858AQ2
Whirlpool LET8858AW0
Whirlpool LET8858AW1
Whirlpool LET8858AW2
Whirlpool LET8858AZ0
Whirlpool LET8858AZ1
Whirlpool LET8858AZ2
Whirlpool LET8858DQ0
Whirlpool LET8858DQ1
Whirlpool LET8858DZ0
Whirlpool LET8858DZ1
Amana LEU-516 Range - S/c S/i Ddraft Gas
Amana LEU-516D Range - S/c S/i Ddraft Gas
Amana LEU-516E Range - S/c S/i Ddraft Gas
Amana LEU-516G Range - S/c S/i Ddraft Gas
Amana LEU108 Range - S/c S/i Ddraft Gas
Whirlpool LEV4434AN0
Whirlpool LEV4434AW0
Whirlpool LEV4436AN0
  #2 (permalink)
Old 02-05-2013, 04:12 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
HI.
Use the multimeter to check:
-If there is 240VAC to the dryer(best if you'll check at the connector block).
-With timer set to dry the contacts BK-R should be closed.
-Check the the continuity of the - heater, thermal fuse, operating thermostat.
Here are the breakdown diagrams and Bulkhead parts for Whirlpool LER8648PW0 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-06-2013, 09:32 AM
Junior Member
Default
OK:
240VAC OK
Thermal fuse OK
Heater OK
Don't know where the operating thermostat is - the charts number parts but don't offer lists with names.
or how to check:
"With timer set to dry the contacts BK-R should be closed"
Could you give more detailed instructions or a different chart?
  #4 (permalink)
Old 02-06-2013, 10:25 AM
Expert
Default
Hi.
The operating thermostat is called "cycling thermostat" on this chart
Part number: 3387134
It's next to the thermal fuse.
In regards of the testing the timer:
Unplug the dryer, turn the timer ON timed-regular.
Remove the Red wire from the R contact from the back of the timer.
Use the multimeter to check the continuity between contacts marked BK and R. Replace the timer if there is no continuity.
The timer Part number: 3979618
On the right side of the diagram I've posted there is a vertical column of the rest of the diagrams, just scroll up or down.
Thank you.
Simon.
__________________
  #5 (permalink)
Old 02-06-2013, 11:59 AM
Junior Member
Default
Simon,
Thank you so much for your detailed description - that really helped.
Well, the operating thermostat seems to be ok. However, mine has four wires attached to it, two red on the outside, which I can remove and test, and are ok. and two purple ones on the inside, but I cannot remove those, so don't know if those are ok, or not.
Second, I tested from R to BK and I get nothing... what I don't understand is that when turned on, the timer works just fine... so how is this causing the heat to not come on?
and this is a very expensive part, it might make more sense to just replace the dryer... ...
Is there a way to connect the wires together for the time being to make it run, until I can get a new dryer?
Thanks again
  #6 (permalink)
Old 02-06-2013, 12:28 PM
Expert
Default
Hello.
The two purple wires are for the tiny thermostat heater, not important in your case.
The BK-R contacts are closed when the timer is on to provide 120VAC to the heater leg.
DO NOT bypass the timer. It's NOT safe.
Simon.
__________________
  #7 (permalink)
Old 02-06-2013, 12:39 PM
Junior Member
Default
Simon,
Thank you so much for your help.
I wish I knew as much as you do about this stuff.
Thanks,
  #8 (permalink)
Old 02-06-2013, 02:30 PM
Expert
Default
It's my pleasure.
Have a great day.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Electric Dryer will not heat scramjet Dryer Repair 11 05-12-2012 02:46 AM
Whirlpool Electric Dryer won't heat up jcarroll1 Dryer Repair 4 09-25-2009 08:48 AM
Whirlpool electric dryer no LOW heat articcatbill Dryer Repair 2 07-08-2009 05:20 PM
Whirlpool electric dryer won't heat pilzperson Dryer Repair 0 04-03-2008 01:46 PM
Whirlpool Electric Dryer--No Heat hnumrich Dryer Repair 0 02-05-2008 06:14 AM
