Discuss
Electric Whirlpool Dryer - no Heat!
 in
Dryer Repair
Bought new heating element about 3 months ago. It worked great. Now - no heat. It runs no problem, just
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric Whirlpool Dryer - no Heat!
  #1 (permalink)
Old 02-05-2013, 11:51 AM
Junior Member
willow5000 is on a distinguished road
Unhappy Electric Whirlpool Dryer - no Heat!
Model Number: LER8648PWO   Brand: Whirlpool   Age: 1 - 5 years
Now - no heat. It runs no problem, just doesn't heat.
After the heat went out, it came back the next day (but not as hot as usual), and today there is nothing at all.
What do I check? what could be the culprit?
thanks
Ads By Google
Related Models
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
Whirlpool LET7646DZ0
Whirlpool LET7646DZ1
Whirlpool LET7646EQ0
Whirlpool LET7646EQ1
Whirlpool LET7646EQ2
Whirlpool LET7646EZ0
Whirlpool LET7646EZ1
Whirlpool LET7646EZ2
Whirlpool LET7848AN0
Whirlpool LET7848AQ0
Whirlpool LET7848AQ1
Whirlpool LET7848AQ2
Whirlpool LET7848AW0
Whirlpool LET7848AZ0
Whirlpool LET7848AZ1
Whirlpool LET7848AZ2
Whirlpool LET7848DQ0
Whirlpool LET7848DQ1
Whirlpool LET7848DZ0
Whirlpool LET7848DZ1
Whirlpool LET8858AN0
Whirlpool LET8858AN1
Whirlpool LET8858AN2
Whirlpool LET8858AQ0
Whirlpool LET8858AQ1
Whirlpool LET8858AQ2
Whirlpool LET8858AW0
Whirlpool LET8858AW1
Whirlpool LET8858AW2
Whirlpool LET8858AZ0
Whirlpool LET8858AZ1
Whirlpool LET8858AZ2
Whirlpool LET8858DQ0
Whirlpool LET8858DQ1
Whirlpool LET8858DZ0
Whirlpool LET8858DZ1
Amana LEU-516 Range - S/c S/i Ddraft Gas
Amana LEU-516D Range - S/c S/i Ddraft Gas
Amana LEU-516E Range - S/c S/i Ddraft Gas
Amana LEU-516G Range - S/c S/i Ddraft Gas
Amana LEU108 Range - S/c S/i Ddraft Gas
Whirlpool LEV4434AN0
Whirlpool LEV4434AW0
Whirlpool LEV4436AN0
  #2 (permalink)
Old 02-07-2013, 02:41 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool LER8648PW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
I would start by checking the heating element with a meter.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and touched the case. This could cause what you describe and now the element is burned out.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 02-07-2013, 12:11 PM
Junior Member
Default
Thank you so much,
I've determined that it is the timer. I even opened it up, and it is nicely burned out in one corner. Do you know why this happens? I mean it's only copper connectors inside; why would it burn out all of a sudden?
Do you know if it would be possible to just replace the burned out metal parts on the inside?
  #4 (permalink)
Old 02-08-2013, 12:58 AM
Senior Expert
APP Volunteer
Default
It probably did not burnout all of a sudden, it probably took some time.
What can happen is that the contacts can get dirty/pit over time. This pitting causes there to be some resistance between the contacts. When current passes through the contacts, heat is generated. This further degrades the contacts and so on and so on till the contacts fail.
I do not know of ant place that sell the timer's inmternal parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Electric Dryer will not heat scramjet Dryer Repair 11 05-12-2012 02:46 AM
Whirlpool Electric Dryer won't heat up jcarroll1 Dryer Repair 4 09-25-2009 08:48 AM
Whirlpool electric dryer no LOW heat articcatbill Dryer Repair 2 07-08-2009 05:20 PM
Whirlpool electric dryer won't heat pilzperson Dryer Repair 0 04-03-2008 01:46 PM
Whirlpool Electric Dryer--No Heat hnumrich Dryer Repair 0 02-05-2008 06:14 AM
