Discuss
No Heat From Dryer
 in
Dryer Repair
I am a new member here and have a Whirlpool dryer that spins but generates no heat. The timer works
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat From Dryer
  #1 (permalink)
Old 02-04-2013, 11:34 PM
Junior Member
D3RDEYE is on a distinguished road
Angry No Heat From Dryer
Model Number: Whirlpool LGR7646EQ0   Brand: Whirlpool   Age: More than 10 years
I am a new member here and have a Whirlpool dryer that spins but generates no heat. The timer works if placed in the "Air Fluff" position, but otherwise it does not move in any other "heat" setting. I have read some of the messages here and see that this might be a fixable problem.
However, to be exactly sure, could someone direct me to the specific dis-assembly and testing thread for this particular model # or, otherwise kindly direct me on how to go about diagnosing the specific malfunctioning part on this unit? Any assistance will be greatly appreciated. Thank you.
Ads By Google
Related Models
Whirlpool WHP1000SB1 Pedestal
Whirlpool WHP1000SK0 Pedestal
Whirlpool WHP1000SK1 Pedestal
Whirlpool WHP1000SL0 Pedestal
Whirlpool WHP1000SL1 Pedestal
Whirlpool WHP1000SQ0 Pedestal
Whirlpool WHP1000SQ1 Pedestal
Whirlpool WHP1000ST0 Pedestal
Whirlpool WHP1000ST1 Pedestal
Whirlpool WHP1000SU1 Pedestal
Whirlpool WHP1500SA0 Pedestal
Whirlpool WHP1500SA1 Pedestal
Maytag WHP1500SA1 Pedestal
Whirlpool WHP1500SB0 Pedestal
Whirlpool WHP1500SB1 Pedestal
Maytag WHP1500SB1 Pedestal
Whirlpool WHP1500SC0 Pedestal
Whirlpool WHP1500SC1 Pedestal
Maytag WHP1500SC1 Pedestal
Whirlpool WHP1500SL0 Pedestal
Whirlpool WHP1500SL1 Pedestal
Maytag WHP1500SL1 Pedestal
Whirlpool WHP1500SQ0 Pedestal
Whirlpool WHP1500SQ1 Pedestal
Maytag WHP1500SQ1 Pedestal
Whirlpool WHP1500ST0 Pedestal
Whirlpool WHP1500ST1 Pedestal
Maytag WHP1500ST1 Pedestal
Whirlpool WHP1500SU0 Pedestal
Whirlpool WHP1500SU1 Pedestal
Maytag WHP1500SU1 Pedestal
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" Electric Range Ceran Cooktop Self Clean
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLH1 Frg(v5) / 27 " Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDH3 Frg(v6) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLH1 Frg(v8) / 27 " Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
  #2 (permalink)
Old 02-05-2013, 12:44 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
First you need to check the timer Part number: 3976580
Use the video clip for the instructions.
Remove one black wire from the timer motor contact and check the resistance. If you read no continuity - then replace the timer.
If not - set the timer to AUTO-REG and check continuity between TM-WB, BK-BU, BK-R, T-W. If any of them are open - replace the timer.
You also should check hi-limit, operating thermostat and thermal fuse for continuity. All of them are at the back of the dryer.
Fuse Part number: 3392519
Here are the breakdown diagrams and Bulkhead parts for Whirlpool LGR7646EQ0 - AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-09-2013, 04:54 PM
Junior Member
Default
Hello Simon, thanks for your response to my post, have been under the weather over here the last couple of days. You directed that I "use the video clip for the instructions", but I do not see any video clip or link to one. Please clarify.
  #4 (permalink)
Old 02-11-2013, 11:28 AM
Expert
Default
Hi.
Click on the fuse picture and you will open another page with video.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
