Discuss
Problems with Whirlpool Electric Dryer
 in
Dryer Repair
The dryer is not heating and we suspected the thermal cut off may need to be replaced. However, on the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Problems with Whirlpool Electric Dryer
View Poll Results: Dryer not heating, and was making a squealing noise.
Dryer not heating 1 100.00%
making squealing noise 0 0%
Voters: 1. You may not vote on this poll
  #1 (permalink)
Old 10-01-2009, 12:25 PM
Junior Member
mdf557 is on a distinguished road
Default Problems with Whirlpool Electric Dryer
Model Number: LEN2000JQ1   Brand: Whirlpool   Age: 5 - 10 years
The dryer is not heating and we suspected the thermal cut off may need to be replaced. However, on the diagram it is showing a 2 piece part when all we are showing on our dryer in a 1 piece part. Please help......................
Sincer Thanks
Ads By Google
Related Models
Whirlpool LEN2000JQ1
Whirlpool LEN2000JQ2
Whirlpool LEN2000JT0
Whirlpool LEN2000JT1
Whirlpool LEN2000JT2
Whirlpool LEN2000KQ0
Whirlpool LEN2000KQ1 29"electric Dryer
Whirlpool LEN2000KQ2 29"electric Dryer
Whirlpool LEN2000KT0
Whirlpool LEN2000KT1 29"electric Dryer
Whirlpool LEN2000LG0
Whirlpool LEN2000LG1 29"electric Dryer
Whirlpool LEN2000LW0
Whirlpool LEN2000LW1 29"electric Dryer
Whirlpool LEN2000PG0 29"electric Dryer
Whirlpool LEN2000PG1 29"electric Dryer
Whirlpool LEN2000PW0 29"electric Dryer
Whirlpool LEN2000PW1 29"electric Dryer
Whirlpool LEN3434AW0
Whirlpool LEN3624BN0
Whirlpool LEN3624BN1
Whirlpool LEN3624BN2
Whirlpool LEN3624BW0
Whirlpool LEN3624BW1
Whirlpool LEN3624BW2
Whirlpool LEN3634DW0
Whirlpool LEN3634DW1
Whirlpool LEP6646AN0
Whirlpool LEP6646AN1
Whirlpool LEP6646AN2
Whirlpool LEP6646AW0
Whirlpool LEP6646AW1
Whirlpool LEP6646AW2
Whirlpool LEP6848AN0
Whirlpool LEP6848AN1
Whirlpool LEP6848AN2
Whirlpool LEP6848AW0
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
Whirlpool LEP7858AW1
Whirlpool LEP7858AW2
Whirlpool LEP7858AZ2
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
  #2 (permalink)
Old 10-01-2009, 01:28 PM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
The first thing that needs to be done is to do a voltage test to see
if there is 240 volts AC where the cord connects to the dryer.
  #3 (permalink)
Old 10-01-2009, 04:46 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LEN2000JQ1 | AppliancePartsPros.com
I believe you are referring to Item 9 in Section 3. It is a thermal fuse (Cut-off) and a Hi-limit thermostat. They should be replaced as a pair. The reason being that the Hi-limit should have opened and regulated the temperature before the thermal fuse blew.
This will also let you check the voltage at the unit.
Just be careful 240 volts is lethal.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problems with GE Electric Dryer Kelly091200 Dryer Repair 1 12-29-2009 05:45 PM
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
Whirlpool Electric Oven Problems broxi Oven Repair (including Ranges and Cooktops) 1 06-30-2009 12:36 PM
Dryer Electric Problems fintasticmp Dryer Repair 2 07-23-2008 12:17 PM
whirlpool electric dryer KRO Dryer Repair 1 04-26-2008 04:27 PM
