| » Whirlpool Dryer GEW9878LWO doesn't stay running |
Model Number: GEW9878LWO Brand: Whirlpool Age: More than 10 years
When starting dryer,the dryer will only run as long as start switch is pressed.
I have tested all switches,replaced the motor,timer and thermistor,checked voltage. And still the dryer will only operate as well as heat as long as you hold the start button in. I have also visually inspected all connections as well as conducted continuity tests on most of the harness. Ads By Google Related Models |
Parts for Whirlpool GEW9878LW0 Dryer - AppliancePartsPros.com Have you checked the motor relay? I believe that the motor and heat relays are the same. Check the numbers on the relays just to be sure. If the same swap the relays and see what happens. If it now runs OK but does not have any heat then you need a new relay.
__________________
Yes I had done exactly that .
Sorry for not explaining that. Is it possible the control board is shot? Not sure what else it can be and I am becoming very interested in launching it into a dumpster. Last edited by jorkvilleyoe : 02-07-2013 at 07:52 AM. |
| Display Modes | |
| Whirlpool electric dryer won't stay running | hanansx6 | Dryer Repair | 0 | 04-08-2012 06:18 PM |
| Dryer will not stay running | clarence ray | Dryer Repair | 0 | 01-02-2011 01:27 PM |
| Whirlpool Dryer wont stay running | ckb24 | Dryer Repair | 10 | 09-12-2010 03:53 PM |
| whirlpool dishwasher won't stay running | davmitch | Dishwasher Repair | 3 | 09-01-2010 07:15 PM |
| Dryer Won't Stay Running | MONA SMITH | Dryer Repair | 1 | 11-16-2009 05:28 AM |
