| » Dryer does not heat (gas) |
Model Number: lgr7646eq0 Brand: Whirlpool Age: 1 - 5 years
I removed the drum and got to the burner assy, when I turn the dryer on the igniter does not even warm up. I don't have an ohm meter. I assume the igniter should be glowing?
I figured it out, I made a jumper wire and jumped the thermal fuse and was able to determine the fuse was bad...popped a new fuse in and I'm back in buisness.
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
