Discuss
Squealing Noise
 in
Dryer Repair
Hi Simon, after repeated attempts to properly seat the drum with the ballhitch attached, I decided to remove it and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Squealing Noise
  #11 (permalink)
Old 04-18-2013, 09:45 PM
Junior Member
moody9207 is on a distinguished road
Default
Hi Simon, after repeated attempts to properly seat the drum with the ballhitch attached, I decided to remove it and check some measurements and I think now that the drum / ballhitch is seating okay, but perhaps I did not apply enough grease. Does a certain level of grease help to hold the drum more firmly? Perhaps the grease acts like packing material.
I recall when I first reattached the drum to the old ballhitch, the drum was certainly held in place, despite finding that the old plastic bearing piece was very much worn away.
I took a picture of the ballhitch in place. Most of the grease I applied has been removed as a result of my repeated attempts so I will apply more. The ballhitch right now moves around enough to clearly tell me that the weight of the drum would certainly pull it down in front.
Any other suggestions for me to solve this?
Also, thanks for your patience with me and my questions.
  #12 (permalink)
Old 04-19-2013, 03:06 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Sorry, never had such a problem.
I always attach the ballhitch to the drum and insert it in to the bearing.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My GE Dryer is making a squealing noise John nut Dryer Repair 3 02-04-2013 11:28 AM
Agitator not working, squealing noise lderubeis Washer Repair 1 03-18-2012 06:09 AM
Washer squealing noise Dave M. Washer Repair 1 06-08-2010 07:19 PM
Squealing Noise mjmorizio@earthlink.net Dryer Repair 2 12-04-2008 09:36 AM
