Discuss
Dryer keeps blowing fuses
 in
Dryer Repair
Hello I have repaired this Kenmore series 90 dryer 4 times now in the past few weeks. Here is a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer keeps blowing fuses
  #1 (permalink)
Old 01-29-2013, 10:13 AM
Junior Member
zerulian is on a distinguished road
Default Dryer keeps blowing fuses
Model Number: 110.60902990   Brand: Kenmore   Age: 5 - 10 years
Hello
I have repaired this Kenmore series 90 dryer 4 times now in the past few weeks. Here is a quick recap.
1 The high limit fuse blew. I took it apart and found the dryer clogged with lint. Cleaned it out completely -- from intake at the heating element to outside vent -- and replaced the fuse (but not the other part that came with it)
2 Fuse blows again. This time I replace both parts figuring that not replacing the other part was a mistake.
3 Fuse blows again. I replace the the cycling thermostat, the high limit fuse, and the other cycling thermostat not located on the heating element.
4 Fuse blows again. This time I replace the high limit fuse, cycling thermostat and the heating element even though it tested at 10.4 ohms. [When I jumped the high limit fuse and watched the element heat up it did not appear evenly red so I figured maybe the element was the real problem.]
The belt broke (no doubt because I had pulled out the drum so many times) and I replaced it.
The fuse has blown once again. This time I rechecked the entire path for blockage -- there is none. I ran the dryer and the flow is strong through the outside vent. It is a short 5-6 foot solid duct with two 90's to the outside.
I am at a loss as to what to try next. What else could it be if there is no blockage and if both cycling thermostats and the heating element were replaced?
Any help would be much appreciated.
zerulian
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 03-29-2013, 12:38 PM
Junior Member
Lmf101 is on a distinguished road
Default
Quote:
Originally Posted by zerulian View Post
Hello
zerulian
I have a similar problem, did you ever find a solution?
  #3 (permalink)
Old 03-30-2013, 03:32 PM
Junior Member
Default
I finally gave up and bought another dryer.
I never really found out what was wrong with it.
Sorry I cannot be of more help. Good luck with yours.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer is Blowing through Fuses! aduersch Dryer Repair 1 11-02-2011 01:37 AM
Dryer blowing thermal fuses RetsoF10 Dryer Repair 1 10-26-2011 01:52 AM
dryer blowing thermal fuses dlynns47 Dryer Repair 3 04-25-2011 09:22 AM
dryer keeps blowing fuses whattheheck4 Dryer Repair 2 04-08-2010 07:02 PM
Dryer is blowing thermal fuses 65gt350 Dryer Repair 11 01-10-2009 08:29 PM
