Discuss
Range - Need help with broiler
 in
Dryer Repair
broiler doesn't work. Tested connectors on back and got 0 volts. tested element which is new and it was fine.....
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Range - Need help with broiler
  #1 (permalink)
Old 01-28-2013, 09:40 PM
Junior Member
jaz2924 is on a distinguished road
Smile Range - Need help with broiler
Model Number: 0RF362LXTS2   Brand: Whirlpool   Age: 5 - 10 years
broiler doesn't work. Tested connectors on back and got 0 volts. tested element which is new and it was fine..... It was ~40 ohms
Ads By Google
Related Models
Amana 10-2NM ROOM AIR CONDITIONER
Frigidaire 1005 DISHWASHER
Frigidaire 1006 DISHWASHER
Amana 1008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 100A-20 ROOM AIR CONDITIONER
Amana 100A-2M ROOM AIR CONDITIONER
Amana 100A-2N ROOM AIR CONDITIONER
Amana 100A-30 ROOM AIR CONDITIONER
Amana 100A-30H ROOM AIR CONDITIONER
Amana 100A-356 ROOM AIR CONDITIONER
Amana 100A-3A ROOM AIR CONDITIONER
Amana 100A-3HN ROOM AIR CONDITIONER
Amana 100A-3M ROOM AIR CONDITIONER
Amana 100A-3N ROOM AIR CONDITIONER
Amana 100A-3P ROOM AIR CONDITIONER
Amana 100A-3PH ROOM AIR CONDITIONER
Amana 100A-3R ROOM AIR CONDITIONER
Amana 100A-3RH ROOM AIR CONDITIONER
Amana 100A-556 ROOM AIR CONDITIONER
Amana 100A-8R ROOM AIR CONDITIONER
Amana 100B-3A ROOM AIR CONDITIONER
Amana 100C-2N ROOM AIR CONDITIONER
Amana 100C-2N1 ROOM AIR CONDITIONER
Amana 100C-2P ROOM AIR CONDITIONER
Amana 100C-2PH ROOM AIR CONDITIONER
Amana 100C-2R ROOM AIR CONDITIONER
Amana 100C-2RH ROOM AIR CONDITIONER
Amana 100C-2RHL ROOM AIR CONDITIONER
Amana 100C-2RL ROOM AIR CONDITIONER
Amana 100C-3N ROOM AIR CONDITIONER
Amana 100C-3N1 ROOM AIR CONDITIONER
Amana 100C-3P ROOM AIR CONDITIONER
Amana 100C-3PH ROOM AIR CONDITIONER
Amana 100C-3R ROOM AIR CONDITIONER
Amana 100C-3RH ROOM AIR CONDITIONER
Amana 100C-3RHL ROOM AIR CONDITIONER
Amana 100C-3RL ROOM AIR CONDITIONER
Amana 100C-8P ROOM AIR CONDITIONER
Amana 100C-8R ROOM AIR CONDITIONER
Amana 100C-8RH ROOM AIR CONDITIONER
Amana 100C-8RHL ROOM AIR CONDITIONER
Amana 100C-8RL ROOM AIR CONDITIONER
Amana 100D-356 ROOM AIR CONDITIONER
Amana 100D-556 ROOM AIR CONDITIONER
Amana 100LA-20 ROOM AIR CONDITIONER
Amana 100LA-2N ROOM AIR CONDITIONER
Amana 100LC-2N ROOM AIR CONDITIONER
Amana 100LC-2P ROOM AIR CONDITIONER
Amana 100LC-2R ROOM AIR CONDITIONER
Amana 100LC-2RH ROOM AIR CONDITIONER
Amana 100LCS-2N ROOM AIR CONDITIONER
Amana 100LCS-2P ROOM AIR CONDITIONER
Hoover 1010
Amana 1010.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1011.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1015.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1020
Amana 1020.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1020.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1021.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1022
Amana 1022.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1026 DISHWASHER
Hoover 1030
Frigidaire 1031-005A DISHWASHER
Hoover 1032
Frigidaire 1032-005A DISHWASHER
Craftsman 10322161 TABLE MITRE SAW
Craftsman 10322180 CRAFTSMAN BENCH SAW
Craftsman 10322181 CRAFTSMAN BENCH SAW
Craftsman 10322420 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322450 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322451 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10323150 CRAFTSMAN JIG SAW
Craftsman 10323151 JIG SAW 18 INCH
Craftsman 10323390 CRAFTSMAN JIG SAW
Craftsman 10323420 BENCH SAW
Craftsman 10323440 JIG SAW
Craftsman 10323830 BENCH SAW (8 INCHES)
Craftsman 10323831 BENCH SAW 8 IN.
Craftsman 10323833 BENCH SAW (8 INCHES)
Craftsman 10324250 CRAFTSMAN 12 INCH BAND SAW
Craftsman 10324260 CRAFTSMAN 12 INCH BAND SAW
Craftsman 10324441 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10324680 FLOOR SAW 10 INCH
Craftsman 10324681 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10325400 BENCH SAW
Craftsman 10329301 CRAFTSMAN 9" RADIAL SAWS
Craftsman 10329310 CRAFTSMAN 9" RADIAL SAWS
Jenn-Air 1035 WALLOVEN- STD ELE
Amana 1035.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1035B DISHWASHER
Frigidaire 1036 DISHWASHER
Jenn-Air 1037 WALLOVEN- STD ELE
Frigidaire 1037B DISHWASHER
Frigidaire 1041-002A DISHWASHER
Amana 1041.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1046 DISHWASHER
Amana 1050.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1050.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1051.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 1053B0A BUILT-IN GAS OVEN
Roper 1053B1A BUILT-IN GAS OVEN
Roper 1053B2A BUILT-IN GAS OVEN
Admiral 1058AF-CW RANGE- S/I STD ELE
Admiral 1058AF-CZ RANGE- S/I STD ELE
Admiral 1058AH-W RANGE- S/I STD ELE
Admiral 1058AH-Z RANGE- S/I STD ELE
Admiral 1058WF-CW RANGE- S/I STD ELE
Admiral 1058WF-CZ RANGE- S/I STD ELE
Admiral 1058WH-W RANGE- S/I STD ELE
Amana 106-2G ROOM AIR CONDITIONER
Amana 106-2GH ROOM AIR CONDITIONER
  #2 (permalink)
Old 01-29-2013, 02:12 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
I cannot find any info on the given model number.
Please check it.
Trace the wires from the broiler element back to the control board.
Some units have a thermal fuse/cut-off in this circuit.
If it does it should be 0 ohms.
Check the wires from the element to the control board.
If all OK then odds are thet you need a new control board.
I am assuming that the stove top and the bake element run OK.
__________________
  #3 (permalink)
Old 01-29-2013, 08:53 AM
Junior Member
Default Whirlpool Range RF362LXTS2
Thank you for your help. The stove top and the bake element run perfectly.
Checking the thermal fuse.
For broiler element to operate correctly what Voltage difference should I see at the element leads?
  #4 (permalink)
Old 01-29-2013, 10:14 AM
Junior Member
Default
tested thermal fuse and saw 0 ohms
tested broil element and got 0 ohms
tested broil element and it had 0 v when in broil mode
tested power and had 240 to left 120 middle, and ground.
tested bake element and it had 240 v when in bake mode
stove top and bake work fine
what am I missing?
  #5 (permalink)
Old 01-29-2013, 12:06 PM
Senior Expert
APP Volunteer
Default
Parts for Whirlpool RF362LXTS2 Range - AppliancePartsPros.com
You should see 240 volts across the broil element.
Something wrong here as it should have some resistance 20 to 50 ohms.
You probably saw 0 because you were using too high of a meter scale so it cannot resolve lower resistances.
Since the fuse is OK and the wiring is OK then I would say that the control board (item 12 in the Control Parts section) is toast.
Looks pretty pricey, it may not be worth fixing the unit unless it is in very good shape.
__________________
  #6 (permalink)
Old 01-30-2013, 11:19 PM
Junior Member
Default Thank you for the help
Probably going to buy a new range....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Gas Range--Burners:Yes. Broiler:Yes. Oven:No kiernanman Oven Repair (including Ranges and Cooktops) 0 01-27-2011 12:31 AM
Oven doesn't work, but range and broiler do jconway1968 Oven Repair (including Ranges and Cooktops) 6 12-02-2010 10:19 AM
Oven and broiler don't light in range feeshdr Oven Repair (including Ranges and Cooktops) 2 03-05-2010 06:19 AM
GE Gas Range Broiler will not shut off korybw Oven Repair (including Ranges and Cooktops) 1 08-14-2009 06:02 PM
Broiler in range will not shut off Hayes Oven Repair (including Ranges and Cooktops) 1 05-29-2008 12:27 PM
