Discuss
Maytag Dyer Flame Does Not Stay Lit
 in
Dryer Repair
Dryer stopped producing heat. When it was working, it took forever to dry clothes. Venting seems OK. Finally, no heat
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dyer Flame Does Not Stay Lit
  #1 (permalink)
Old 01-28-2013, 10:03 AM
Junior Member
jgwalter is on a distinguished road
Default Maytag Dyer Flame Does Not Stay Lit
Model Number: LDG8704AAE   Brand: Maytag   Age: More than 10 years
Finally, no heat at all, and ignitor tested as failed. I replaced ignitor, flame lights, but goes out after about a minute. About a minute or so later, it re-lights.
That seems like a very short cycle, especially with it running with the door removed.
Radiant sensor and cycling sensor test OK. I did not test high-limit sensor, but I would expect, if it were cycling off the high-limit, it would be due to an airflow blockage, which it does not have.
When running, it seems warm in the drum. Warm, but not real hot.
What is a common cycle time for the flame?
Ads By Google
Related Models
Maytag LDG8704AAE Dryer - Gas
Maytag LDG8704AAL Dryer - Gas
Maytag LDG8704AAM Dryer - Gas
Maytag LDG8706AAE Dryer - Gas
Maytag LDG8706AAM Dryer - Gas
Maytag LDG8804AAE Dryer - Gas
Maytag LDG8804AAL Dryer - Gas
Maytag LDG8804AAM Dryer - Gas
Maytag LDG882 Dryer - Gas
Maytag LDG8824AAE Dryer - Gas
Maytag LDG8824AAL Dryer - Gas
Maytag LDG8824AAM Dryer - Gas
Maytag LDG882D Dryer - Gas
Maytag LDG8904AAE Dryer - Gas
Maytag LDG8904AAL Dryer - Gas
Maytag LDG8904AAM Dryer - Gas
Norge LDG912700 Dryer - Gas
Norge LDG912724 Dryer - Gas
Norge LDG9127A Dryer - Gas
Norge LDG9127H Dryer - Gas
Norge LDG9127W Dryer - Gas
Maytag LDG9206AAE Dryer - Gas
Maytag LDG9206AAM Dryer - Gas
Maytag LDG9206ABE Dryer - Gas
Maytag LDG9304AAE Dryer - Gas
Maytag LDG9304AAL Dryer - Gas
Maytag LDG9304AAM Dryer - Gas
Maytag LDG9304ABE Dryer - Gas
Maytag LDG9304ABM Dryer - Gas
Maytag LDG9306AAE Dryer - Gas
Maytag LDG9306AAM Dryer - Gas
Maytag LDG9306ABE Dryer - Gas
Maytag LDG9306ABM Dryer - Gas
Maytag LDG9314AAE Dryer - Gas
Maytag LDG9314AAL Dryer - Gas
Maytag LDG9314AAM Dryer - Gas
Maytag LDG9316AAE Dryer - Gas
Maytag LDG9316AAM Dryer - Gas
Maytag LDG9334AAE Dryer - Gas
Maytag LDG9334AAL Dryer - Gas
Maytag LDG9334AAM Dryer - Gas
Maytag LDG9606AAE Dryer - Gas
Maytag LDG9606AAM Dryer - Gas
Maytag LDG9606ABE Dryer - Gas
Maytag LDG9606ABM Dryer - Gas
Maytag LDG9700 Dryer - Gas
Maytag LDG9700AAL Dryer - Gas
Maytag LDG9700AAW Dryer - Gas
Maytag LDG9700ABL Dryer - Gas
Maytag LDG9700ABW Dryer - Gas
Maytag LDG9701AAL Dryer - Gas
Maytag LDG9701AAW Dryer - Gas
Maytag LDG9701ABL Dryer - Gas
Maytag LDG9701ABW Dryer - Gas
Maytag LDG9800 Dryer - Gas
Maytag LDG9800AAL Dryer - Gas
Maytag LDG9800AAW Dryer - Gas
Maytag LDG9800ABL Dryer - Gas
Maytag LDG9800ABW Dryer - Gas
Maytag LDG9801AAL Dryer - Gas
Maytag LDG9801AAW Dryer - Gas
Maytag LDG9801ABL Dryer - Gas
Maytag LDG9801ABW Dryer - Gas
Maytag LDG9804AAE Dryer - Gas
Maytag LDG9804AAL Dryer - Gas
Maytag LDG9804AAM Dryer - Gas
Maytag LDG9806AAE Dryer - Gas
Maytag LDG9806AAM Dryer - Gas
Maytag LDG9814AAE Dryer - Gas
Maytag LDG9814AAL Dryer - Gas
Maytag LDG9814AAM Dryer - Gas
Maytag LDG9824AAE Dryer - Gas
Maytag LDG9824AAL Dryer - Gas
Maytag LDG9824AAM Dryer - Gas
Maytag LDG9900 Dryer - Gas
Maytag LDG9900AAL Dryer - Gas
Maytag LDG9900AAW Dryer - Gas
Maytag LDG9900ABL Dryer - Gas
Maytag LDG9900ABW Dryer - Gas
Maytag LDG9900BAL Dryer - Gas
Maytag LDG9900BAW Dryer - Gas
Maytag LDG9900BBL Dryer - Gas
Maytag LDG9900BBW Dryer - Gas
Maytag LDG9900R Dryer - Gas
Maytag LDG9904AAE Dryer - Gas
Maytag LDG9904AAL Dryer - Gas
Maytag LDG9904AAM Dryer - Gas
Admiral LDGA100AAL Dryer - Gas
Admiral LDGA100AAW Dryer - Gas
Admiral LDGA100BAE Dryer - Gas
Admiral LDGA100BAM Dryer - Gas
Admiral LDGA200AAE Dryer - Gas
Admiral LDGA200AAL Dryer - Gas
Admiral LDGA200AAM Dryer - Gas
Admiral LDGA200AAW Dryer - Gas
Admiral LDGA300AGE Dryer - Gas
Admiral LDGA300AGL Dryer - Gas
Admiral LDGA300AGW Dryer - Gas
Admiral LDGA400AAE Dryer - Gas
Admiral LDGA400AAL Dryer - Gas
Admiral LDGA400AAM Dryer - Gas
Admiral LDGA400AAW Dryer - Gas
Admiral LDGA500AAE Dryer - Gas
Admiral LDGA500AAL Dryer - Gas
Admiral LDGA500AAM Dryer - Gas
Admiral LDGA500AAW Dryer - Gas
Hoover LDGH200AAV Dryer - Gas
Hoover LDGH200AGV Dryer - Gas
Maytag LDGS30PC1 Dryer - Gas
Whirlpool LDI3001W0
Whirlpool LDI5521W0
Whirlpool LDI5521W1
Whirlpool LDI5701W0
Whirlpool LDI5701W1
Whirlpool LDI5701W2
Whirlpool LDI5751W0
Whirlpool LDI5751W1
Whirlpool LDI5801W0
Whirlpool LDI5801W1
Whirlpool LDI5921W0
  #2 (permalink)
Old 01-28-2013, 12:48 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Do not run the dryer with out the door closed. The dryer overheats. Put some wet clothes inside, close the door, remove the vent hose from the back of the dryer and run one load.
If it drys good, put the vent back and run it again. If it's start taking longer then usual check the vent.
The flame should stay on at the beginning of the cycle for 1.5 to 3 min then off for 1 min.
Here are the breakdown diagrams and 07-Motor Drive parts for Maytag LDG8704AAE - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-29-2013, 04:18 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Post the results.
Simon.
That logic doesn't seem to make sense to me, but in practice it seems to work that way.
With the door off, the flame only stays on for about 15 seconds, then cycles back on again in about a minute or so. With the door closed, it still was not producing much heat, and a medium sized load was taking several hours to dry.
So, I took apart the fan housing, and found a moderate-size clump of lint. However, I also noticed that the fan, while turning with the drum, was free-wheeling rather easily as well. So, it may have been stopped by the lint, or at least slowed.
I'm not sure if it is supposed to freewheel like that? I removed the clamp, cleaned it off, and replaced it to what seemed like a little tighter of a fit.
All back together now, and it appears to have a higher air flow, and the drum is getting a lot hotter. With it all closed up, I cannot tell how long the flame stays on, but it must be staying on longer?
Thanks for the help. Maybe now I can get another 20 years out of this machine? :-)
  #4 (permalink)
Old 01-29-2013, 04:37 PM
Expert
Default
Hi.
You perfectly detected the problem - the blower wheel is shot.
Replace it Part number: Y303836
Good luck.
Simon.
__________________
  #5 (permalink)
Old 01-30-2013, 06:30 AM
Junior Member
Default
Hi.
Good luck.
Simon.
Thanks again. I ordered the part, along with a new belt.
  #6 (permalink)
Old 01-30-2013, 10:55 AM
Expert
Default
My pleasure.
Simon.
__________________
  #7 (permalink)
Old 05-02-2013, 07:10 PM
Member
thorning is on a distinguished road
Default
I also noted the blower wheel on a Maytag dryer that was freewheeling on the shaft . The problem was the small amount of material in the collar design allows it to eventually wallow out and it will slip on the shaft thus reducing the output air flow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas flame does not stay on long lorneh Dryer Repair 0 11-29-2010 02:45 PM
Dyer won't stay running GoldaLn Dryer Repair 1 01-15-2010 03:05 AM
Maytag clothes dryer flame won't stay lit Guyslienare Dryer Repair 18 12-19-2009 01:27 PM
Maytag Neptune gas dyer does not stay hot squarecookie Dryer Repair 4 04-20-2009 04:39 AM
Dryer flame will not stay on Ray Worden Dryer Repair 1 10-19-2008 05:52 AM
