Discuss
Roper Heating problems
 in
Dryer Repair
So I can see the igniter glow, then it goes out. The thermal fuse went out and was replaced about
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Heating problems
  #1 (permalink)
Old 09-30-2009, 08:15 PM
Junior Member
bugspray34 is on a distinguished road
Default Roper Heating problems
Model Number: RGX5634KQ2   Brand: Roper   Age: 5 - 10 years
So I can see the igniter glow, then it goes out. The thermal fuse went out and was replaced about 6 months ago. I pulled everything apart and did the following as posted elsewhere:
There are five major electrical parts involved in the heating process:
1. Thermal fuse
2. Cycling thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
If the thermal fuse is blown – it has to be replaced together with the cycling thermostat.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 ± 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 ± 25 Ohms
b) across the left and the right terminals – 560 ± 25 Ohms
Everything checked out ok except the resistance numbers for the coil with 3 terminals. The #'s were different than shown above. I put it all back together and got it to work twice then it stopped again, only the glowing but no torch. I pulled it all back apart real quick and the left and middle terminals were open. By the time I pulled out the screws and pulled the coil, those 2 terminals was getting readings again.
Am I safe to guess this is the problem?
Ads By Google
Related Models
Roper RGX5634KQ2 DRYER
Roper RGX5634KQ3 29" GAS DRYER
Roper RGX5634PQ0 29" GAS DRYER
Roper RGX5635EN0 GAS DRYER
Roper RGX5635EN1 DRYERS
Roper RGX5635EN2 GAS DRYER
Roper RGX5635EN3 GAS DRYER
Roper RGX5635EQ0 GAS DRYER
Roper RGX5635EQ1 DRYERS
Roper RGX5635EQ2 GAS DRYER
Roper RGX5635EQ3 GAS DRYER
Roper RGX5635EW0 GAS DRYER
Roper RGX5635EW1 DRYERS
Roper RGX5635EW2 GAS DRYER
Roper RGX5635EW3 GAS DRYER
Roper RGX5636AL1 GAS DRYER
Roper RGX5636AL2 GAS DRYER
Roper RGX5636AW0 Residential Dryer
Roper RGX5636AW1 GAS DRYER
Roper RGX5636AW2 GAS DRYER
Roper RGX6634PQ0 29" GAS DRYER
Roper RGX6634RQ0 29" GAS DRYER
Roper RGX6634RQ1 29" GAS DRYER
Roper RGX6646AL1 GAS DRYER
Roper RGX6646AL2 GAS DRYER
Roper RGX6646AL3 GAS DRYER
Roper RGX6646AQ2 GAS DRYER
Roper RGX6646AQ3 GAS DRYER
Roper RGX6646AW0 Residential Dryer
Roper RGX6646AW1 GAS DRYER
Roper RGX6646AW2 GAS DRYER
Roper RGX6646AW3 GAS DRYER
Roper RH0500RAW00 CHEST FREEZER
Roper RH0500RDW00 CHEST FREEZER
Roper RH0500REW00 CHEST FREEZER
Roper RH0500REW01 CHEST FREEZER
Roper RH0500REW02 CHEST FREEZER
Roper RH0500RWW00 Freezers*
Roper RH0588RBW00 CHEST FREEZER
Roper RH0588REW00 CHEST FREEZER
Roper RH0588REW01 CHEST FREEZER
Roper RH0588REW02 CHEST FREEZER
Roper RH0599RBW00 CHEST FREEZER
Roper RH0599REW00 CHEST FREEZER
Roper RH0599REW01 CHEST FREEZER
Roper RH0599REW02 CHEST FREEZER
Roper RH0799RBW00 CHEST FREEZER
Roper RH0799REW00 CHEST FREEZER
Roper RH0799REW01 CHEST FREEZER
Roper RH0799REW06 FREEZERS
Jenn-Air RH100 HOOD
Roper RH1000RAW00 Freezers*
Roper RH1000RDW00 CHEST FREEZER
Roper RH1000REW00 CHEST FREEZER
Roper RH1000REW01 CHEST FREEZER
Roper RH1000REW05 CHEST FREEZER
Roper RH1000REW06 FREEZERS
Roper RH1000RYW00 Freezers*
Jenn-Air RH101 HOOD
Roper RH1099RBW00 CHEST FREEZER
Roper RH1099REW00 CHEST FREEZER
Roper RH1099REW06 FREEZERS
Roper RH1200RWW00 Freezers*
Roper RH1200RXW00 Freezers*
Whirlpool RH123 Air-conditioner/heat pump
Whirlpool RH123A1 AIR CONDITIONER
Whirlpool RH123A2 AIR CONDITIONERS
Jenn-Air RH130 HOOD
Roper RH1500RAW00 CHEST FREEZER
Roper RH1500RDW00 CHEST FREEZER
Roper RH1500REW00 CHEST FREEZER
Roper RH1500REW01 FREEZERS
Roper RH1500REW02 CHEST FREEZER
Roper RH1500REW03 FREEZERS
Roper RH1500REW04 FREEZER
Roper RH1500REW05 CHEST FREEZER
Roper RH1500REW06 FREEZERS
Roper RH1500RWW00 Freezers*
Roper RH1500RXW00 Freezers*
Roper RH1599RBW00 CHEST FREEZER
Roper RH1599REW00 CHEST FREEZER
Roper RH1599REW03 FREEZERS
Roper RH1599REW04 FREEZERS
Roper RH1599REW06 FREEZERS
Jenn-Air RH170 HOOD
Jenn-Air RH180B HOOD
Jenn-Air RH180W HOOD
Whirlpool RH183 Air-conditioner/heat pump
Jenn-Air RH186B HOOD
Jenn-Air RH186W HOOD
Jenn-Air RH200 HOOD
Whirlpool RH2024XLW0 Range Hood
Whirlpool RH2024XLW1 Range Hood
Whirlpool RH2030WXW0 Range Hood
Whirlpool RH2030XDB0 30" RANGE HOOD
Whirlpool RH2030XDB1 RANGE HOOD
Whirlpool RH2030XDQ0 30" RANGE HOOD
Whirlpool RH2030XDQ1 RANGE HOOD
Whirlpool RH2030XDS0 30" RANGE HOOD
Whirlpool RH2030XDS1 RANGE HOOD
Whirlpool RH2030XDZ0 30" RANGE HOOD
Whirlpool RH2030XDZ1 RANGE HOOD
Whirlpool RH2030XJB0 30" RANGE HOOD
Whirlpool RH2030XJB1 HOODS
Whirlpool RH2030XJB2 RANGE HOOD
Whirlpool RH2030XJB3 30" RANGE HOOD
Whirlpool RH2030XJQ0 30" RANGE HOOD
Whirlpool RH2030XJQ1 HOODS
Whirlpool RH2030XJQ2 RANGE HOOD
Whirlpool RH2030XJQ3 30" RANGE HOOD
Whirlpool RH2030XJT0 30" RANGE HOOD
Whirlpool RH2030XJT1 HOODS
Whirlpool RH2030XJT2 RANGE HOOD
Whirlpool RH2030XJT3 30" RANGE HOOD
Whirlpool RH2030XJZ1 HOODS
Whirlpool RH2030XJZ2 RANGE HOOD
Whirlpool RH2030XLW0 Range Hood
Whirlpool RH2030XLW1 Range Hood
Whirlpool RH2030XXW0 Range Hood
Whirlpool RH2036XLW1 Range Hood
  #2 (permalink)
Old 10-02-2009, 06:31 AM
Senior Member
applianceman is on a distinguished road
Default
I would say replace both coils on the gas valve. When the igniter goes out the coils should open the gas valve at the same time lighting the flame. Most likely the coils. Gas Dryer Repair Guide
  #3 (permalink)
Old 10-03-2009, 04:30 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
Feel the coils after they fail. The hot one will be the bad boy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper spin cycle problems. TIA! K.D. Washer Repair 16 01-25-2010 07:57 PM
Roper Washer Problems momof3angels Washer Repair 1 08-19-2009 07:16 AM
Old Roper oven heating problems oven delima Oven Repair (including Ranges and Cooktops) 1 02-14-2009 02:36 PM
Roper Dryer problems b0001744 Dryer Repair 1 08-29-2008 11:44 AM
Roper Gas Dryer not heating Brian K Dryer Repair 3 01-15-2008 11:33 AM
