| » dryer timer not working, heats ok |
Model Number: 11066722694 Brand: Kenmore Age: 5 - 10 years
Kenmore 70 series dryer model 11066722694. My timer is not advancing. I replaced it with a new timer, but it didnt fix problem. Dryer seems to heat up ok, seems to dry clothes ok, but we have to turn it off. We can turn it off by the knob, and it will stop when we open door. To restart we have to push button on control panel. Are there any other parts that will keep timer from advancing??????
If it is not moving then it will not advance to the off position.
I cannot find a wiring diagram for this unit. Hopefully you found one in the control console. By doing some research it looks like this is a 240 volt timer motor although I am not 100% sure of this. So if it is 240 then in timed dry the motor will get power from L2 red, through the motor's centrifugal switch, through a set of timer contacts WB/TM to L1 black. You will have to check this circuit for continuity. You did say the the dryer seems to dry clothes OK if it is not like it should be it could be that the centrifugal switch is not closing and the element is grounded. This would be a long shot. One way to check it is to set the timer to a mid cycle and see if the heater comes on without starting the machine. Again without a wiring diagram the above is just guessing.
__________________
Quote:
Sorry but I am confused.
In your first post you said the heater was coming on, now you say it does not come on. Have the symptoms changed. On most units the timer will advance in timed dry irrespective if the heater is OK. But in auto modes the timer will not advance if the heater coil is blown. The timer motor gets power through the heater coil when the thermostat shuts it off. Sounds like you may have a blown heater coil. Also just hearing the timer motor is not good enough. You have to actually see the timer knob advance.
__________________
| Display Modes | |
| Dryer Heats But Timer Dial Does Not Advance | karenoregon | Dryer Repair | 1 | 11-26-2011 04:48 AM |
| Dryer Heats Timer Doesn't Move | johnf0246 | Dryer Repair | 13 | 06-02-2010 04:00 PM |
| timer not advancing dryer heats does not turn off | hyperlk | Dryer Repair | 1 | 09-27-2009 05:55 PM |
| Gas Dryer just barely heats and timer will not advance | Robert Fran | Refrigerator & Freezer Repair | 0 | 06-03-2009 12:55 PM |
| Dryer Heats fine but timer won't advance | PaulCutone | Dryer Repair | 1 | 04-07-2009 03:08 AM |
