| » gas dryer trips breaker when rying to heat |
Model Number: GGW9200LQ0 Brand: Whirlpool Age: 5 - 10 years
Need help on what to check. The dryer will run fine on air dry. The drum tumbles, blower works, ect. But when you select any of the heat settings, when you press and hold the start button, there will be a quick buzzing sound and it trips the breaker for the dryer outlet. Any thoughts?
There is a short somewhere in the heating circuit. You may want to check all parts in that circuit for continuity. They are: the wire harness and connections, the thermal fuse, the high limit thermostat, the flame sensor, the igniter and the gas valve coils.
If there is nothing wrong then the problem most likely is a bad control board. Post the results. Here is the Tech sheet for the dryer. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GGW9200LQ0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Dryer Trips Breaker | one80two | Dryer Repair | 10 | 11-30-2009 07:59 AM |
| Dryer trips breaker | rsmotorsports | Dryer Repair | 4 | 04-12-2009 06:59 PM |
| Dryer trips breaker | dayeaw | Dryer Repair | 7 | 02-24-2009 03:59 PM |
| gas dryer trips breaker | cerriel | Dryer Repair | 1 | 02-20-2009 04:33 PM |
| GE dryer trips breaker as soon as I turn it on | the adam | Dryer Repair | 1 | 02-05-2009 04:55 AM |
