Discuss
My Dryer has power but does not turn on
 in
Dryer Repair
I have a whirlpool cabrio model # wed6200swo. The dryer was in the middle of a cycle, made popping noise
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » My Dryer has power but does not turn on
  #1 (permalink)
Old 01-21-2013, 04:37 PM
Junior Member
Sportsman7 is on a distinguished road
Default My Dryer has power but does not turn on
Brand: Whirlpool   Age: 5 - 10 years
I have a whirlpool cabrio model # wed6200swo. The dryer was in the middle of a cycle, made popping noise and turned off. When you push power the power comes on but when you push start it beeps and the only the sensing light comes on. I pulled off the back panel and checked the fuse, there was continuity. I checked the exhaust thermistor and found it was reading about 11,000. Did the diagnostic on the dryer and it said f25. Was told that code meant the inlet thermistor was bad, I checked that and did get a 0 reading on the multimeter so I replaced. Got it all back together, did not put the back panel on or secure the exhaust hose. Pushed power, then start and got the sensing light and a beep. So does anybody have any idea of what I can now try besides calling a repair man.
thanks
  #2 (permalink)
Old 01-22-2013, 03:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
You may want to check the belt. If the belt is good, check the broken belt switch (#22 at the diagram) for continuity and the wires connected to the switch.
- The belt Part number: 8547168
- The broken belt switch assembly Part number: 8566208
Here are the breakdown diagrams and Parts for Whirlpool WED6200SW0 Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Power Light Comes On But The Dryer Will Not Turn Or Get Hot Please Help Me EdwardArk Dryer Repair 0 02-10-2012 05:58 PM
Dryer has power but will not turn on tfo98 Dryer Repair 0 01-12-2012 09:55 PM
Dryer has power will not turn on Kelly R. Dryer Repair 3 11-24-2010 05:08 AM
Dryer will not turn on has power other test done KCgallimore Dryer Repair 4 07-10-2010 08:55 PM
Dryer does not turn has power to plug and unit wxperez Dryer Repair 2 05-24-2009 09:09 AM
