Discuss
Increasingly Loud GE Dryer - Is a complete Rear Drum Bearing Kit (or more) required?
 in
Dryer Repair
My dryer is a General Electric, Model # DDE5944VHLAD, with Serial #DR203481G. In April of 2008, I replaced the heating
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Increasingly Loud GE Dryer - Is a complete Rear Drum Bearing Kit (or more) required?
  #1 (permalink)
Old 01-21-2013, 02:26 AM
Junior Member
Matthew W. is on a distinguished road
Default Increasingly Loud GE Dryer - Is a complete Rear Drum Bearing Kit (or more) required?
Model Number: DDE5944VHLAD   Brand: GE   Age: More than 10 years
In April of 2008, I replaced the heating coils, idler pulley assembly, drive belt, and (I believe) the rear drum (polymer) bearing as well. At that time, I noticed that the (original) nylon drum slides/supports in the front of the unit were rather worn, and because I needed to get the dryer up and functional, it was simpler and less expensive to purchase a used set of slides (that had far more material left on them than the ones in my dryer, and with little apparent wear) from a local appliance recycling firm a few miles from my home, than to wait a few more days to receive a brand new pair of slides.
Once I got the new components installed and the dryer reassembled, all seemed to work well (since 2008), that is, at least until the past few months. Prior to installing the aforementioned parts nearly 5 years ago, there were no noticeable sounds that I recall. Aside from the worn out heating coils and drive belt, I replaced the other parts more as a matter of preventive maintenance, due to their age, while I could access them. What started out as an occasional squeak just a few months ago has now turned into a loud "thrum", droning on as the drum rotates. I have checked to see that the drum is not obstructed, by rotating it back and forth with my hand on one of the drum "baffles". Since I'm not moving the drum very fast, I don't detect a noise, and it appears to rotate pretty freely. When in operation, the noise seems loudest from the rear, bouncing back towards me from off the wall behind the dryer. I've listened to the lower front of the dryer, but I can't discern if the motor is at fault.
I haven't yet disassembled the dryer for inspection since I last serviced it, so I don't recall what type of rear drum support assembly is actually installed on my particular unit. I'm aware there are types with bearing plates having a pass-through for a grounding strip, like this kit (WE25M40), and a less expensive version without that feature. I've attempted to verify that the Rear Drum Bearing Kit #WE25M40 is appropriate for my dryer, but your system is telling me that it is NOT compatible. I'm not even finding my Model # listed anywhere, which makes me more frustrated. I can't see that while this dryer is admittedly old, getting parts like this would be that difficult, or at least not as difficult as locating some electrical components.
I must ask though, given that I've replaced the other related components BESIDES the full bearing kit contents, might installing a complete rear drum bearing kit (and even a new set of drum slides) solve the noise issue I'm experiencing now? I'm hopeful it's NOT the motor (as I believe you suggested to other customers with similar issues, on the question section for the bearing kit), as I had to replace the drive motor on our Whirlpool washer this year, and I would rather be spared a similar expense for an even older dryer. We're just not in a position quite yet to purchase brand new units, and don't want to buy ones we haven't fully researched.
Thanks very much for reading this and for whatever information you can provide.
Ads By Google
Related Models
General Electric DDE5944VJL Electric dryer
General Electric DDE6350BBL Electric dryer
General Electric DDE6350BCL Electric dryer
General Electric DDE6350GAL Electric dryer
General Electric DDE6350GBL Electric dryer
General Electric DDE6407LAL Electric dryer
General Electric DDE6500GAL Electric dryer
General Electric DDE6500GBL Electric dryer
General Electric DDE6608LAL Electric dryer
General Electric DDE7000SBLAA Electric dryer
General Electric DDE7000SBLWH Electric dryer
General Electric DDE7000SBLWW Electric dryer
General Electric DDE7007SBLAA Electric dryer
General Electric DDE7007SBLWW Electric dryer
General Electric DDE7100MAL Electric dryer
General Electric DDE7100MBL Electric dryer
General Electric DDE7100MCL Electric dryer
General Electric DDE7100MDL Electric dryer
General Electric DDE7100RAL Electric dryer
General Electric DDE7100SBLAA Electric dryer
General Electric DDE7100SBLWW Electric dryer
General Electric DDE7106RAL Electric dryer
General Electric DDE7107RAL Electric dryer
General Electric DDE7108VJL Electric dryer
General Electric DDE7109SBLAA Electric dryer
General Electric DDE7109SBLWW Electric dryer
General Electric DDE7109VML Electric dryer
General Electric DDE7109VNL Electric dryer
General Electric DDE7110VML Electric dryer
General Electric DDE7110VNL Electric dryer
General Electric DDE7200RAL ELECTRIC DRYER
General Electric DDE7200RALAA Electric dryer
General Electric DDE7200RALWW Electric dryer
General Electric DDE7200SBLAA Electric dryer
General Electric DDE7200SBLWH Electric dryer
General Electric DDE7200SBLWW Electric dryer
General Electric DDE7206 ELECTRIC DRYER
General Electric DDE7206MAL Electric dryer
General Electric DDE7206MBL Electric dryer
General Electric DDE7206MCL Electric dryer
General Electric DDE7206MDL Electric dryer
General Electric DDE7206RAL Electric dryer
General Electric DDE7207RAL Electric dryer
General Electric DDE7207SBLAA Electric dryer
General Electric DDE7207SBLWW Electric dryer
General Electric DDE7208 ELECTRIC DRYER
General Electric DDE7208MAL Electric dryer
General Electric DDE7208MBL Electric dryer
General Electric DDE7208MCL Electric dryer
General Electric DDE7208MDL Electric dryer
General Electric DDE7208MXL Electric dryer
General Electric DDE7209RALAA Electric dryer
General Electric DDE7209RALWW Electric dryer
General Electric DDE7500BBL Electric dryer
General Electric DDE7500GAL Electric dryer
General Electric DDE7500GBL Electric dryer
General Electric DDE7600RAL Electric dryer
General Electric DDE7606 ELECTRIC DRYER
General Electric DDE7606MAL Electric dryer
General Electric DDE7606MBL Electric dryer
General Electric DDE7606MCL Electric dryer
General Electric DDE7606MDL Electric dryer
General Electric DDE7608 ELECTRIC DRYER
General Electric DDE7608MAL Electric dryer
General Electric DDE7608MBL Electric dryer
General Electric DDE7608MCL Electric dryer
General Electric DDE7608MDL Electric dryer
General Electric DDE7900BBL Electric dryer
General Electric DDE7900GAL Electric dryer
General Electric DDE7900GBL Electric dryer
General Electric DDE7900GDL Electric dryer
General Electric DDE7900MAL Electric dryer
General Electric DDE7900MBL Electric dryer
General Electric DDE7900MCL Electric dryer
General Electric DDE7900MDL Electric dryer
General Electric DDE7900RAL ELECTRIC DRYER
General Electric DDE7900RALAA Electric dryer
General Electric DDE7900RALWW Electric dryer
General Electric DDE7900SAL Electric dryer
General Electric DDE7900SBLAA Electric dryer
General Electric DDE7900SBLWW Electric dryer
General Electric DDE7905SBLAA Electric dryer
General Electric DDE7905SBLWW Electric dryer
General Electric DDE7906LAL Electric dryer
General Electric DDE7906RAL Electric dryer
General Electric DDE7907RAL Electric dryer
General Electric DDE7909RAL Electric dryer
General Electric DDE8000MAL Electric dryer
General Electric DDE8000MBL Electric dryer
General Electric DDE8100DAL Electric dryer
General Electric DDE8100DBL GE DRYERS, ELECTRIC
General Electric DDE8107MAL Electric dryer
General Electric DDE8108VHL Electric dryer
General Electric DDE8108VJL GE DRYERS, ELECTRIC
General Electric DDE8109VML Electric dryer
General Electric DDE8200BAC Electric dryer
General Electric DDE8200DAL Electric dryer
General Electric DDE8200DBL GE DRYERS, ELECTRIC
General Electric DDE8200GAL Electric dryer
General Electric DDE8200GBL Electric dryer
General Electric DDE8200GDL Electric dryer
General Electric DDE8200RAM Electric dryer
General Electric DDE8200RBM Electric dryer
General Electric DDE8200RCM Electric dryer
General Electric DDE8200RFM Electric dryer
General Electric DDE8200SAMAA Electric dryer
General Electric DDE8200SAMWW Electric dryer
General Electric DDE8200SBMAA Electric dryer
General Electric DDE8200SBMWW Electric dryer
General Electric DDE8500RAM Electric dryer
General Electric DDE8500RBM Electric dryer
General Electric DDE8500RCM Electric dryer
General Electric DDE8500RFM Electric dryer
General Electric DDE8500SAMAA Electric dryer
General Electric DDE8500SAMWH Electric dryer
General Electric DDE8500SAMWW Electric dryer
General Electric DDE8500SBMAA Electric dryer
General Electric DDE8500SBMWH Electric dryer
General Electric DDE8500SBMWW Electric dryer
General Electric DDE8505SAMAA Electric dryer
  #2 (permalink)
Old 01-21-2013, 05:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Matthew,
The model number you posted does not come up anywhere but the closest model numbers I found (Model DDE5944VEL and Model DDE5944VJL) are pretty similar and can be used to look up a moving parts.
The bearing kit Part number: WE25M40
should work with your dryer but you probably can use just the bearing Part number: WE3X75
Part number: WE3X75
The best way to determine which parts exactly needed to fix this problem is to take the dryer apart and inspect all moving parts.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer rear drum bearing replacement Brittontr Dryer Repair 0 12-12-2011 06:40 PM
Rear Drum Bearing Bushing pjenks6668 Dryer Repair 1 08-10-2009 06:07 AM
need complete instructions to replce rear drum support rollers reddyfreddy Dryer Repair 1 05-18-2008 01:34 PM
replacing rear bearing on ge dryer ejwtlw-1 Dryer Repair 1 01-09-2008 01:59 PM
how do I: remove rear drum bearing frigid front load? treefrog Washer Repair 0 08-19-2007 01:12 PM
