Discuss
MDE9700AYW Heats then trips out and kills the thermostat.
 in
Dryer Repair
Ok. To start, this thing is now as clean as it was when it came off the factory floor. Vent,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » MDE9700AYW Heats then trips out and kills the thermostat.
  #1 (permalink)
Old 01-18-2013, 02:37 PM
Junior Member
fatheroffive is on a distinguished road
Default MDE9700AYW Heats then trips out and kills the thermostat.
Brand: Maytag   Age: 1 - 5 years
Ok. To start, this thing is now as clean as it was when it came off the factory floor. Vent, hose all new. It is the typical heating problem and so I checked the element... 10.2 ohm. no sags no breaks all clean. Next the hi limit themostat on heating box. 10 ohms. Theromstat, less than 1 omh until it heats for 3 mins and then it burns out. Cleaned and checked the motor belt switch and it is good. Traced all the wires all the way back to the breaker box. No shorts.... Is my problem in the control board and if so, is there a easy way to check the contacts. Ordered two more theromstats for on the heater assy. The two on the vent duct are also good in resistance. any help?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat from maytag mde9700ayw Mitsuguy Dryer Repair 1 09-28-2012 02:55 AM
Maytag MDE9700AYW Will not run aschiemann Dryer Repair 3 12-20-2011 12:16 PM
Only heats for a short time; already changed thermal fuse and cycling thermostat srelliott Dryer Repair 0 10-19-2011 07:49 PM
Dryer heats up then trips breaker jerryb1969 Dryer Repair 4 05-20-2011 12:19 PM
Surge kills oven adons Oven Repair (including Ranges and Cooktops) 0 05-04-2010 10:48 AM
