Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer starting issues (http://forum.appliancepartspros.com/dryer-repair/515548-dryer-starting-issues.html)
Deals best 01-16-2013 05:30 AM
I live in an apartment that has washer and dryer combo (washer on bottom and dryer on top). I was using my dryer one day when the dryer starter switch failed, and the dryer won't start anymore. At least I think it might be the dryer starter switch. Pulled everything apart and everything seemed ok, no burnt wires or anything. What could be causing my dryer not to start?:confused:
Gene 01-16-2013 05:01 PM
Quote:
Originally Posted by Deals best (Post 794923)
...the dryer starter switch failed...
Could you please specify which part exactly failed: the knob of the start switch or the switch itself? If it was the switch then where did it fail and what happen with it's wires?
Deals best 01-16-2013 06:48 PM
button
The button doesn't work to start dryer. It a push button I just called it a starter switch I thought that's what it was called.
Gene 01-17-2013 02:08 PM
Pull the unit out of the wall. Remove the rear cover and check the thermal fuse fro continuity.
- The thermal fuse Part number: 3392519
