Hope someone can help me - I put my clothes in the dryer(Whirlpool Duet), set everything, but when I pressed START it shows the sensor working and it would not start. Then it showed error code FO1. I have reset the breaker and I do have power. I was able to activate the diagnostic test mode but didn't get much help with that either. From all my research, it appears I need to replace the electronic machine control board. Can anyone verify that? It's a pricey part - is this easy to repair?:confused:
