Discuss
belt slipping on motor pully
 in
Dryer Repair
My dryer stoped tumbling sort of...had to lighten load. Got worse and worse. It's either the belt or the motor
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » belt slipping on motor pully
  #1 (permalink)
Old 01-13-2013, 05:02 PM
Junior Member
justino is on a distinguished road
Default belt slipping on motor pully
Model Number: sde305dayw   Brand: Maytag   Age: More than 10 years
My dryer stoped tumbling sort of...had to lighten load. Got worse and worse. It's either the belt or the motor I thought. The pulley on the motor just spins and does not catch the belt to turn the drum. What the heck am I doing wrong. Is it the belt that needs to be replaced . Drum does lag a little. You can barley push it up 1/8 of an inch.. it almost seams like it helps when I push up the drum the little bit I can. It almost makes it grabs the belt better. Is it the belt, do i need a new one. did I put the belt on correct.. flat side down on the drum right?
Ads By Google
Related Models
Maytag SDE305DAYW Dryer - Ele
Maytag SDE305DAZW Dryer - Ele
Maytag SDE3606AYQ Dryer - Ele
Maytag SDE3606AYW Dryer - Ele
Maytag SDE3606AZW Dryer - Ele
Maytag SDE4000AYW Dryer - Ele
Maytag SDE4000AZW Dryer - Ele
Maytag SDE405DAYW Dryer - Ele
Maytag SDE4606AYW Dryer - Ele
Maytag SDE4606AZW Dryer - Ele
Maytag SDE505DAYQ Dryer - Ele
Maytag SDE505DAYW Dryer - Ele
Maytag SDE505DAZW Dryer - Ele
Maytag SDE515DAYW Dryer - Ele
Maytag SDE515DAZW Dryer - Ele
Maytag SDE5401AYQ Dryer - Ele
Maytag SDE5401AYW Dryer - Ele
Maytag SDE5401AZW Dryer - Ele
Maytag SDE5701AYQ Dryer - Ele
Maytag SDE5701AYW Dryer - Ele
Maytag SDE5701AZW Dryer - Ele
Whirlpool SDF3700W0
Whirlpool SDF3700W2
Whirlpool SDF3700W4
Whirlpool SDF3700W5
Whirlpool SDF3700W6
Whirlpool SDF4000W0
Whirlpool SDF4000W1
Whirlpool SDF4500W0
Whirlpool SDF4500W1
Whirlpool SDF4500W2
Whirlpool SDF4500W3
Whirlpool SDF4500W4
Whirlpool SDF5000W0
Whirlpool SDF5000W1
Whirlpool SDF5000W2
Whirlpool SDF5000W3
Whirlpool SDF5000W4
Whirlpool SDF5000W5
Whirlpool SDF5000W6
Whirlpool SDF6000W0
Whirlpool SDF6000W1
Whirlpool SDF6000W2
Whirlpool SDF6000W3
Whirlpool SDF6000W4
Whirlpool SDF7000W0
Whirlpool SDF7000W1
Whirlpool SDF7800W0
Whirlpool SDF7800W1
Whirlpool SDF7800W2
Whirlpool SDF7800W3
Whirlpool SDF7801W0
Whirlpool SDF8000W0
Whirlpool SDF8000W1
Maytag SDG2606AWW Dryer - Gas
Maytag SDG305DAWW Dryer - Gas
Maytag SDG3606AWQ Dryer - Gas
Maytag SDG3606AWW Dryer - Gas
Maytag SDG4000AWW Dryer - Gas
Maytag SDG405DAWW Dryer - Gas
Maytag SDG4606AWW Dryer - Gas
Maytag SDG505DAWQ Dryer - Gas
Maytag SDG505DAWW Dryer - Gas
Maytag SDG505DAXW Dryer - Gas
Maytag SDG515DAWW Dryer - Gas
Maytag SDG5401AWQ Dryer - Gas
Maytag SDG5401AWW Dryer - Gas
Maytag SDG5401AXW Dryer - Gas
Maytag SDG5701AWQ Dryer - Gas
Maytag SDG5701AWW Dryer - Gas
Maytag SDG5701AXW Dryer - Gas
Whirlpool SDH481B0
Whirlpool SDH501B20
Amana SDI22A Ref - SXS/I&W
Amana SDI22A-A Ref - SXS/I&W
Amana SDI22A-AG Ref - SXS/I&W
Amana SDI22A-C Ref - SXS/I&W
Amana SDI22B Ref - SXS/I&W
Amana SDI22B-A Ref - SXS/I&W
Amana SDI22B-C Ref - SXS/I&W
Amana SDI22B-G Ref - SXS/I&W
Amana SDI22B-L Ref - SXS/I&W
Amana SDI22C Ref - SXS/I&W
Amana SDI22C-A Ref - SXS/I&W
Amana SDI22C-C Ref - SXS/I&W
Amana SDI22C-G Ref - SXS/I&W
Amana SDI22C-L Ref - SXS/I&W
Amana SDI22D Ref - SXS/I&W
Amana SDI22E Ref - SXS/I&W
Amana SDI22E-1-A Ref - SXS/I&W
Amana SDI22E-1-C Ref - SXS/I&W
Amana SDI22E-A Ref - SXS/I&W
Amana SDI22E-C Ref - SXS/I&W
Amana SDI22E-G Ref - SXS/I&W
Amana SDI22E-L Ref - SXS/I&W
Amana SDI22E1 Ref - SXS/I&W
Amana SDI22E1G Ref - SXS/I&W
Amana SDI22E1L Ref - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 Ref - SXS/I&W
Amana SDI22F-1-G Ref - SXS/I&W
Amana SDI22F-1-L Ref - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA Ref - SXS/I&W
Amana SDI22FC Ref - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
  #2 (permalink)
Old 01-14-2013, 03:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Sounds like the belt is bad. Make sure it did not fail into the drum groove. For the belt proper installation you can check the dryer belt diagram here.
Also check the idler pulley tension spring and the pulley itself.
- The belt Part number: 40111201
Here are the breakdown diagrams and Parts for Maytag SDE305DAYW Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Belt keeps slipping off after motor swap Markedup Washer Repair 0 11-08-2012 04:55 AM
Belt slipping carlous Washer Repair 0 12-27-2010 08:42 AM
motor, belt & trans pully spin, no agitation/spin cycle slavens Washer Repair 2 05-08-2010 04:10 PM
Belt & pully Marion13 Dryer Repair 1 12-02-2009 05:11 PM
belt/drum/pully lilphil Dryer Repair 1 11-14-2007 01:12 PM
