| » New element, thermostats good, No heat |
Model Number: DWLR473ETOWW Brand: GE Age: More than 10 years
Electric dryer DWLR473ETOWW GE. The element looked like it was burnt into so I replaced that. No heat. I then went and checked all of the thermostats with an Ohm meter, no resistance. I don't know what else to check. (I am a novice btw)
Hi.
By saying "no resistance" do you mean continuity?Did you take one wire off the thermostats when checking continuity? Have you checked if there is 240VAC at the dryer? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Thanks simon. Yes the wires were taken off of the thermostats before checking continuity. There is 240VAC at the dryer. We checked the timer. We unplugged the two black wires that has each end going into the back of the timer. There was no continuity on these two wires. They were on C and T. (others were A,B,C,X etc.) I dont have any of the schematics for the wires so I don't know if my logic is correct. Does this mean the timer is bad? |
Hi.
Unplug the dryer, set the timer to time dry, selector switch to high. Timer contacts B-A,B-C,T-X should be closed. Selector switch contacts 1-3, 1-4, 5-2 closed. Motor switch contacts 1-2 closed. There are total 5 thermostats (one for the motor) must be closed. Here are the breakdown diagram and Drum, Heater Asem., Blower & Drive Assembly parts for GE DWLR473ET0WW - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 01-15-2013 at 01:35 PM. |
Hi.
To check the motor switch M1-M2 continuity the dryer should run. I'm sorry if it's sounds as I doubt your expertise, but there is nothing ells to check. Go again through the thermostats and make sure there is 240 VAC to the dryer connector block. Simon.
__________________
Not a bit thanks for helping. The motor is running, everything except the element. I have double checked the thermostats. I checked the 240 volts at the wall receptacle. I will check inside the dryer connections for 240 VAC.
I finally found the problem. The black wire coming off the motor had arced. The wire burnt into inside the wire harness. I pulled out the wire, it was green with corrosion. I guess with time the insulation may melt off. Do they sell the wire harnesses etc? I checked the parts link couldn't find any. Thanks.
Hi.
I'm afraid they don't offer the harness. Get the same wire size (preferably high temp.) and use the butt connector. Simon.
__________________
| Display Modes | |
| Heating element & Thermostats | luttrell7263 | Dishwasher Repair | 0 | 05-13-2011 10:09 AM |
| No heat after replacing element & thermostats | jvjgolfnut | Dryer Repair | 2 | 12-15-2010 07:20 PM |
| Dryer still does not heat. Where are the Thermostats | tulhardox | Dryer Repair | 1 | 02-26-2010 09:48 PM |
| no heat heating element good | mikesracecar | Dryer Repair | 1 | 10-29-2009 10:17 AM |
| off and on heat-thermostats working | jeverett | Dryer Repair | 5 | 02-15-2009 10:36 AM |
