| » GE dryer timer replaced, but cycles ae different! |
Model Number: DDE5900RAL Brand: GE Age: More than 10 years
A plastic ring inside the timer of our 20 yr old dryer broke, so I searched for and ordered a compatible replacement timer. The original part# was WE04X0795. The replacement timer part# is WE4X795, & is described as "functionally equivalent". However.....the cycles are completely different! The only thing the same is the "OFF" position at 12o'clock. Our dryer has push buttons to select High heat, Medium heat & No heat. I suspect that the replacement timer has those 3 options incorporated in the selector knob, as the dryer now stops & starts in additional places & the degree of heat varies.
I googled the part #, & it is usually found on GE DDE9600RAM. Can anyone supply a picture of the backsplash assembly, so I can see what thecycles are? Thank you! Voodoochildiyguy Ads By Google Related Models |
I cannot find a picture of the faceplate, tried several places.
But following is the operators manual for this unit which may help. http://www.geappliances.com/search/o...fs/49-9780.PDF
__________________
| Display Modes | |
| Dryer Timer Continues to Run - Dryer Drys and Cycles | casper6418 | Dryer Repair | 0 | 12-26-2011 01:17 PM |
| Dryer wont heat up and timer cycles dont work. | ggordon007 | Dryer Repair | 0 | 08-03-2009 06:47 AM |
| Only half timer cycles work on Maytag Dryer | JmJoyce | Dryer Repair | 5 | 07-16-2009 05:04 PM |
| Replaced dryer timer & it doesn't work | CLACOV | Dryer Repair | 7 | 03-23-2009 07:10 AM |
| dryer timer auto cycles don't work | mikedudl | Dryer Repair | 0 | 04-29-2008 09:52 AM |
