Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   GE dryer timer replaced, but cycles ae different! (http://forum.appliancepartspros.com/dryer-repair/515047-ge-dryer-timer-replaced-but-cycles-ae-different.html)
voodoochildiyguy 01-08-2013 02:03 PM
A plastic ring inside the timer of our 20 yr old dryer broke, so I searched for and ordered a compatible replacement timer. The original part# was WE04X0795. The replacement timer part# is WE4X795, & is described as "functionally equivalent". However.....the cycles are completely different! The only thing the same is the "OFF" position at 12o'clock. Our dryer has push buttons to select High heat, Medium heat & No heat. I suspect that the replacement timer has those 3 options incorporated in the selector knob, as the dryer now stops & starts in additional places & the degree of heat varies.
I googled the part #, & it is usually found on GE DDE9600RAM. Can anyone supply a picture of the backsplash assembly, so I can see what thecycles are?
Thank you!
Voodoochildiyguy
denman 01-09-2013 02:09 AM
I cannot find a picture of the faceplate, tried several places.
But following is the operators manual for this unit which may help.
http://www.geappliances.com/search/o...fs/49-9780.PDF
voodoochildiyguy 01-10-2013 12:15 PM
Replacement timer with different cycles....
Dear denman,
Thank you for the link to the Owners Manual. The picture on page 6 shows the layout of the Regular, Perm Press &Timed Cycles. I'll try these out!
