Discuss
Dryer turns no heat
 in
Dryer Repair
Electric dryer turns but does not heat. Checked power coming into dryer, got 240 volts between the outside legs and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer turns no heat
  #1 (permalink)
Old 01-08-2013, 09:29 AM
Hog Hog is offline
Junior Member
Hog is on a distinguished road
Default Dryer turns no heat
Model Number: Wed6200sw1   Brand: Whirlpool   Age: 1 - 5 years
Electric dryer turns but does not heat. Checked power coming into dryer, got 240 volts between the outside legs and 125 volts between the inside leg and each outside leg. Single element heat strip. Measured 9.8 ohms on heat strip. Thermal cut off and high limit thermostat both measured 0 ohms. Exhaust thermistor measured 13.73 ohms. Inlet thermistor measured 54 ohms. Ran diagnostic check with control panel and it gives a f25 code which indicated inlet thermistor is shorted. Went to parts store and asked for inlet thermistor and they gave me thermal cut off kit (FTP 279816). It didn't solve the problem. Had service technician come out to house and he wanted to replace control panel. Couldn't see spending $200 on a 2 year old dryer and then getting a 60 day warranty. Any suggestions before I replace dryer?
Ads By Google
Related Models
Whirlpool WED6200SW1 29" Electric Dryer
Whirlpool WED6400SB0 29"electric Dryer
Whirlpool WED6400SB1 29"electric Dryer
Whirlpool WED6400SG0 29"electric Dryer
Whirlpool WED6400SG1 29" Electric Dryer
Whirlpool WED6400SW0 29"electric Dryer
Whirlpool WED6400SW1 29" Electric Dryer
Whirlpool WED8300SB0 27" Electric Dryer
Whirlpool WED8300SB1 27" Electric Dryer
Whirlpool WED8300SB2 27" Electric Dryer
Whirlpool WED8300SW0 27" Electric Dryer
Whirlpool WED8300SW1 27" Electric Dryer
Whirlpool WED8300SW2 27" Electric Dryer
Whirlpool WED8410SW0 27"electric Dryer
Whirlpool WED8410SW1 27" Electric Dryer
Whirlpool WED8410SW2 27" Electric Dryer
Whirlpool WED8500SR0 27"electric Dryer
Whirlpool WED9200SQ0 Electric Dryer
Whirlpool WED9400SB0 Electric Dryer
Whirlpool WED9400ST0 Electric Dryer
Whirlpool WED9400SU0 Electric Dryer
Whirlpool WED9400SW0 Electric Dryer
Whirlpool WED9400SZ0 Electric Dryer
Whirlpool WED9500TC0 Electric Dryer
Whirlpool WED9500TU0 Electric Dryer
Whirlpool WED9500TW0 Electric Dryer
Whirlpool WED9600SU0 Electric Dryer
Whirlpool WED9600TA0 27" Electric Dryer
Whirlpool WED9600TB0 27" Electric Dryer
Whirlpool WED9600TU0 27" Electric Dryer
Whirlpool WED9600TW0 27" Electric Dryer
Whirlpool WED9600TZ0 27" Electric Dryer
White Westinghouse WEF303PHDA White Westinghouse/electric Range
White Westinghouse WEF303PHDB White Westinghouse/electric Range
White Westinghouse WEF303PHWA White Westinghouse/electric Range
White Westinghouse WEF303PHWB White Westinghouse/electric Range
White Westinghouse WEF311SHDA White Westinghouse/electric Range
White Westinghouse WEF311SHWA White Westinghouse/electric Range
Frigidaire WEF322BADA Wwh(v1) / Electric Range
Frigidaire WEF322BADB Wwh(v1) / Electric Range
Frigidaire WEF322BADC Wwh(v2) / Electric Range
Frigidaire WEF322BADD Wwh(v1) / Electric Range
Frigidaire WEF322BAWA Wwh(v2) / Electric Range
Frigidaire WEF322BAWB Wwh(v3) / Electric Range
Frigidaire WEF322BAWC Wwh(v4) / Electric Range
Frigidaire WEF322BAWD Wwh(v2) / Electric Range
Frigidaire WEF322BEDA Wwh(v1) / Electric Range
Frigidaire WEF322BEDB Wwh(v1) / Electric Range
Frigidaire WEF322BEWA Wwh(v2) / Electric Range
Frigidaire WEF322BEWB Wwh(v2) / Electric Range
Frigidaire WEF322BEWC Frg(v0) / Electric Range
Frigidaire WEF322SADA Wwh(v1) / Electric Range
Frigidaire WEF322SADB Wwh(v1) / Electric Range
Frigidaire WEF322SADC Wwh(v5) / Electric Range
Frigidaire WEF322SADD Wwh(v3) / Electric Range
Frigidaire WEF322SAWA Wwh(v2) / Electric Range
Frigidaire WEF322SAWB Wwh(v2) / Electric Range
Frigidaire WEF322SAWC Wwh(v6) / Electric Range
Frigidaire WEF322SAWD Wwh(v4) / Electric Range
Frigidaire WEF350BADB Wwh(v1) / Electric Range
Frigidaire WEF350BADC Wwh(v1) / Electric Range
Frigidaire WEF350BAWB Wwh(v2) / Electric Range
Frigidaire WEF350BAWC Wwh(v2) / Electric Range
Frigidaire WEF350CASA Wwh(v0) / Electric Range
White Westinghouse WEF350ESA White Westinghouse/range
White Westinghouse WEF350ESB White Westinghouse/range
Frigidaire WEF350SADA Wwh(v1) / Electric Range
Frigidaire WEF350SADB Wwh(v1) / Electric Range
Frigidaire WEF350SADC Wwh(v3) / Electric Range
Frigidaire WEF350SAWA Wwh(v2) / Electric Range
Frigidaire WEF350SAWB Wwh(v2) / Electric Range
Frigidaire WEF350SAWC Wwh(v4) / Electric Range
White Westinghouse WEF351ESA White Westinghouse/range
White Westinghouse WEF351ESB White Westinghouse/range
Frigidaire WEF352BADA Wwh(v1) / Electric Range
Frigidaire WEF352BADB Wwh(v2) / Electric Range
Frigidaire WEF352BAWA Wwh(v3) / Electric Range
Frigidaire WEF352BAWB Wwh(v4) / Electric Range
Frigidaire WEF352BEDA Wwh(v1) / Electric Range
Frigidaire WEF352BEDB Wwh(v1) / Electric Range
Frigidaire WEF352BEDC Wwh(v1) / Electric Range
Frigidaire WEF352BEWA Wwh(v2) / Electric Range
Frigidaire WEF352BEWB Wwh(v2) / Electric Range
Frigidaire WEF352BEWC Wwh(v2) / Electric Range
Frigidaire WEF357BADA Wwh(v1) / Electric Range
Frigidaire WEF357BADB Wwh(v1) / Electric Range
Frigidaire WEF357BADC Wwh(v1) / Electric Range
Frigidaire WEF357BADD Wwh(v2) / Electric Range
Frigidaire WEF357BAWA Wwh(v2) / Electric Range
Frigidaire WEF357BAWB Wwh(v2) / Electric Range
Frigidaire WEF357BAWC Wwh(v3) / Electric Range
Frigidaire WEF357BAWD Wwh(v4) / Electric Range
White Westinghouse WEF360ESB White Westinghouse/range
White Westinghouse WEF360ESC White Westinghouse/range
White Westinghouse WEF360ESD White Westinghouse/range
White Westinghouse WEF361ESA White Westinghouse/range
White Westinghouse WEF361ESB White Westinghouse/range
White Westinghouse WEF361ESC White Westinghouse/range
White Westinghouse WEF361ESD White Westinghouse/range
White Westinghouse WEF365BHDA White Westinghouse/electric Range
White Westinghouse WEF365BHDB White Westinghouse/electric Range
White Westinghouse WEF365BHWA White Westinghouse/electric Range
White Westinghouse WEF365BHWB White Westinghouse/electric Range
White Westinghouse WER111ES0 White Westinghouse/dryer
White Westinghouse WER211CES0 White Westinghouse/dryer
White Westinghouse WER211ES0 White Westinghouse/dryer
Whirlpool WERC3100PQ0 30" Electric Freestanding Self Clean Convection Oven
Whirlpool WERC3100PQ1 30" Electric Freestanding Self Clean Convection Oven
Whirlpool WERC3100PQ2 30" Electric Freestanding Self Clean Convection Oven
Whirlpool WERC4101SB0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool WERC4101SB1 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool WERC4101SB2 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool WERC4101SQ0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool WERC4101SQ1 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool WERC4101SQ2 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool WERE3000PB4 30" Electric Freestanding Standard Clean Range
Whirlpool WERE3000PB5 30" Electric Freestanding Standard Clean Range
Whirlpool WERE3000PQ0 30" Electric Freestanding Standard Clean Range
Whirlpool WERE3000PQ1 30" Electric Freestanding Standard Clean Range
Whirlpool WERE3000PQ2 30" Electric Freestanding Standard Clean Range
  #2 (permalink)
Old 01-08-2013, 10:41 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
HI.
According the wiring diagram the thermistors are measured in K ohm, so your reading should be 13.73kohm and 54kohm.
If that so then thermistors should be OK.
The inlet thermistor is Part number: 8577891
See if replacing of it will solve the problem. If not - check the harness and plugs at the control board and replace the board.
Remember that if you get the parts from APP you may return any of them even installed ones.
Here are the breakdown diagrams and Top and Console parts for Whirlpool WED6200SW1 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer turns on but no heat pstraight Dryer Repair 1 10-27-2011 11:45 AM
No Heat when dryer turns on drmerrill Dryer Repair 3 04-22-2010 05:50 AM
Frigidaire dryer turns but no heat MartinF Dryer Repair 3 01-20-2010 06:37 PM
Dryer doesn't heat while drum turns IMTSam Dryer Repair 0 12-03-2007 08:36 AM
