Discuss
Maytag Gas Dryer Heat continuously on
 in
Dryer Repair
I have a Maytag gas dryer and it recently gave a problem with heating. The heat will come on when
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Gas Dryer Heat continuously on
  #1 (permalink)
Old 01-07-2013, 05:09 PM
Junior Member
ghunghun is on a distinguished road
Default Maytag Gas Dryer Heat continuously on
Brand: Maytag   Age: Less than 1 year
I have a Maytag gas dryer and it recently gave a problem with heating. The heat will come on when I switch it on first time. After few mins the heat would shut off, then after few secs igniter would flow to bright red but the heat will not start this time. The igniter would keep illuminating to bright red about every 20 secs, but the heat wouldn't start.
After following the recommendations in many forums, we nailed down that the problem was with the Gas valve coil. I replaced the gas valve coil. Now the heat comes on for the first time, and stays on forever (I tried a max of 7 mins, and had to stop the dryer because it became too hot - when I opened the dryer the clothes were too hot and almost burnt my hand). Any suggestions on what is wrong now?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer runs continuously Palmer123 Dryer Repair 11 01-13-2011 10:39 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Maytag dryer runs continuously on timer and auto s2zeller Dryer Repair 3 10-14-2009 10:23 AM
Maytag dishwasher drains continuously jt1022 Dishwasher Repair 7 11-03-2008 03:15 PM
Won't heat continuously bakewella Oven Repair (including Ranges and Cooktops) 0 11-24-2007 06:40 PM
